Output Capacitor Upgrading Questions
jrihs · 178073
Offline NightFlight
Reply #210 on: January 24, 2014, 12:21:55 PM
For the objectivist re-cap burn-in a quick google search brought up this:
http://www.diyaudio.com/forums/parts/81355-capacitor-burn-break.html
You'l have to sign in to get the images.
Offline free
Reply #211 on: January 24, 2014, 09:05:49 PM
Grainger49,
    .  .  .    You say "The film replacements are a whole 'nother animal." do you mean in terms of sound?
Good film caps are much different than electrolytics.  To start with, most electrolytics have a polarity.  Film caps don't.
They are made with very different technologies.  For instance you can get a good 3300uF 180V for ~$8, you can get a nice film 1.0uF 200V (film are usually higher voltages) for $14.50.  That is 1/3300 smaller capacitance.
See, a whole 'nother animal.
2673 to be precise, but yeah, didn't thought it would be such a diff. Usually caps have the problem of having a very low energy density. Even the best ones have like 10x less than a battery but they can be recharged very quickly over 500k times.
Just read what JamieMcC posted, interesting. Also read some specs. From what I understand film caps are sensitive and may improve sound. Have yet to hear it myself.
« Last Edit: January 24, 2014, 09:11:32 PM by free »
Reply #213 on: January 25, 2014, 09:21:36 AM
Tantalum capacitors generally have more measurable distortion than electrolytics, so they are generally avoided in the signal path.
Offline JamieMcC
Reply #214 on: February 02, 2014, 07:18:55 AM
Well I suppose it was inevitable I have had a JFX  2.2uF 250V Polypropylene Film cap that has been sitting in my parts box for a while now (I brought it at the same time as the 100uf films as it only cost £1.72) and ended up soldering it in as film bypass cap across the last electrolytic filter cap in the Crack earlier today.
 I feel there has been a slight improvement in fluidity and presence a touch more body to vocals and also the top end has slightly more crispness to the shimmers and tinkles without importantly for me adding any brightness.
 It now opens up a can of worms with respect to trying something like a PIO or SIO or further bypassing of the current bypassing cap with a smaller Teflon.
I will let the cap burn in for a week or two in situ while I mull over which options to have fun experimenting with next.
(https://www.head-fi.org/content/type/61/id/1031351/width/900/height/675/flags/LL)
« Last Edit: February 22, 2014, 11:47:25 PM by JamieMcC »
Reply #215 on: February 22, 2014, 05:42:13 AM
Not sure if this has been posted before but its an interesting read.  For anybody just interested in power supply or coupling caps you can probably just skip to part 5 or 6.
Capacitor Sound Series: http://www.scribd.com/doc/2610442/capacitor-sound
Offline Strikkflypilot
  • Shellac fiddler
Reply #216 on: May 11, 2014, 11:57:35 AM
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #217 on: May 11, 2014, 12:24:10 PM
No not really, they are still electrolytic capacitors.  Those bi-polar styles are basically two capacitors end to end inside a single package so they probably sound worse.
I wouldn't bother replacing the stock caps with anything unless they were Polypropylene film, easy to spot as they will be huge!
  • Shellac fiddler
Reply #218 on: May 11, 2014, 12:28:36 PM
Thanks.
I try finding an "ideal" upgrade cap to the stock. Not easy.
Basically I dont want anything to get worse than stock, then just add more clarity from mids and up.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Reply #219 on: May 11, 2014, 01:33:29 PM
Hi guys!
I am new to this whole cap thing
Would these be an upgrade tomthe stock caps?
http://www.ebay.com/itm/4pcs-NEW-BC-PHILIPS-043-100UF-250V-21x38mm-L-Life-HI-END-AXIAL-CAP-FOR-AUDIO-/171303408745?pt=Vintage_Electronics_R2&hash=item27e27a9469
Which cap are you going to replace?  Recommendations vary depending on which.
  • Shellac fiddler
Reply #220 on: May 11, 2014, 05:36:23 PM
@Grainger
It seems that the most audible difference would be upgrade the output caps,
so Ill start there.
Happy to hear Your thoughts
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline JamieMcC
Reply #221 on: May 11, 2014, 09:13:34 PM
A rough guide for a pair of capacitors
$10 or less you could try adding 1uf film bypass to the electrolytic capacitors
$30 approx and a little time spent ebay hunting you will find standard 100uf film capacitors used/surplus
$60-$100  and ever upwards new branded audio film capacitors
  • Shellac fiddler
Reply #222 on: May 11, 2014, 11:16:09 PM
Thanks Jamie.
It looks like a Mundorf MCap 250v 100uF bypassed by a Mundorf Supreme 1uF
would be sweet.
Any thoughts?
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Reply #223 on: May 11, 2014, 11:41:03 PM
The output caps are a large value.  I agree with Mcandmar, another electrolytic won't get you where you should be.
What you are looking for is a film cap.  Daytons are inexpensive for that value and voltage rating.  They will make an appreciable difference in the sound.
Do a search and read this thread, you will find a pretty good list of film caps available that will make an appreciable difference.  (I don't have a Crack, so haven't done this myself)
Offline serpent68
Reply #224 on: May 12, 2014, 05:57:14 AM
Thanks Jamie.
would be sweet.
Any thoughts?
Yes, that's a very nice option.  I have the Mundorf MCap 100uF, but bypassed with a 1uF Jantzen Superior Z-Cap.  A big step up from the stock electrolytics.
