Weird Voltage Readings, LED and Tube problems
Doc B. · 6554
on: April 12, 2012, 10:31:10 AM
New member Nightloyd is having some issues starting a new thread, so I have initiated it for him.
Offline Nightloyd
Reply #1 on: April 12, 2012, 10:48:23 AM
Thanks for the help Doc B. !
Hello Bottlehead forum members,
So i got my Crack OTL with the 240VAC and i assembled it yesterday.
My first problem was that the rocker switch melted which led to that it didn't work at all. I solved it by circumventing the switch.
I should also note that all Ohm readings were correct.
Now to the problem i have at the moment:
I get alot of bad voltage readings (Se list below).
The 2 LED's dosen't light up.
And the last problem i have noticed is that the 12AU7 Tube lights up and gets warm but the 6080/6AS7 Tube dosen't.
Voltage Readings:
Terminal - My reading - Expected reading
2 - 225 - 170
4 - 225 - 170
5 - 27 - 90
7 - 27 - 100
9 - 0 - 100
13 - 225 - 170
15 - 0 - 185
A1 - 27 - 90
A3 - 0 - 1,5
A7 - 180 - 0
A8 - 18 - 1,5
B1 - 228 - 90
B2 - 229 - 170
B3 - 27 - 100
B4 - 27 - 90
B5 - 230 - 170
B6 - 0 - 100
Here are some pictues of how i assemlbed it:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg703.imageshack.us%2Fimg703%2F8495%2Fdsc0120hj.th.jpg&hash=a58a38bbb3924e09f8c6cb9e9dce995a96177c41)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg862.imageshack.us%2Fimg862%2F1682%2Fdsc0117d.th.jpg&hash=3805e80679be1011692661f4d2757fec4bf2ccaf)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg9.imageshack.us%2Fimg9%2F7725%2Fdsc0116xfz.th.jpg&hash=03d6cb429d2198e95928066906c942e84ab13dc1)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fimg849.imageshack.us%2Fimg849%2F7995%2Fdsc0115ca.th.jpg&hash=9374abb95af16384b8736fb9543f2360d1fe682c)
I hope you guys can help me out with solving this.
/Nightloyd
« Last Edit: April 12, 2012, 11:06:21 AM by Nightloyd »
Offline HiFi Builder Guy
    • HiFi Builder Guy Facebook
Reply #2 on: April 12, 2012, 11:12:31 AM
It appears your octal socket is flipped.  The gap should face the front.
Shawn
Shawn
HiFi Builder Guy
Offline Nightloyd
Reply #3 on: April 13, 2012, 09:26:00 AM
Shawn
Thank you so much for the help, i get correct readings on everything now.
But i don't get any sound in the right channel and one of the LED's don't glow.
Does this mean that the LED is broken?
Reply #4 on: April 13, 2012, 09:51:40 AM
Don't feel bad.  That is just the kind of thing I would do and I've been at this a long, long time.  Trust me, you are in good company.
Check the orientation of the LEDs first.  They are a booger to get right.  Yes, they can be broken but are most often put in backward.  They don't light backward.
Offline Nightloyd
Reply #5 on: April 13, 2012, 09:58:54 AM
I checked and the the stripe is toward the center.
Maybe i should say that it's the LED connected to A8.
« Last Edit: April 13, 2012, 10:24:39 AM by Nightloyd »
Reply #6 on: April 13, 2012, 10:22:40 AM
Ok, the banded end is the "cathode" which means it should go toward ground.  It sounds like it is right.
What is the voltage at A6 and A8?  These voltages should be off since the right channel is not conducting.
Offline Nightloyd
Reply #7 on: April 14, 2012, 02:13:58 AM
Okey i have no mesured the voltage of A6 and A8
A6: 143V
A8: 11,7V
And it should be like this:
A6: 90V
A8: 1.5V
And that's way off, i guess this means that i need to replace the LED?
Reply #8 on: April 14, 2012, 02:34:45 AM
I expected A6, the plate, to be higher voltage than specified but didn't expect A8 to be high also.  This is looking at the second triode in the tube.
When the tube doesn't conduct, or turn on, the plate has higher voltage on it because it isn't passing current through the tube.  But the 11.7V on the cathode, A8, is odd.
Doc, Paul, Paul?
Reply #9 on: April 14, 2012, 06:00:00 AM
Usually, a high cathode voltage indicates the LED is backwards. Sometimes it is not connected (bad solder joint), or it is just soldered to the wrong terminal. In any case, it is not conducting current from A8 to ground.
Reply #10 on: April 14, 2012, 06:03:31 AM
Does the high voltage also happen if it is damaged, open?
Offline Nightloyd
Reply #11 on: April 14, 2012, 08:53:54 AM
Can i replace the LED with anykind of LED?
Or does it have to be the HLMP-6000?
Offline Laudanum
Reply #12 on: April 14, 2012, 10:08:36 AM
I dont know where you are but Farnell has them ... http://uk.farnell.com/avago-technologies/hlmp-6000/led-submin-red/dp/1003184
The Queen will send replacements out to you for free but being overseas, it may not be as quick.  Depends on how anxious you are I guess.
Desmond G.
Offline Nightloyd
Reply #13 on: April 14, 2012, 10:15:16 AM
I saw that Farnell had them in Sweden too (i live in Sweden), but could i use another LED instead that's goes to about 3V? Or would that shorten the lifespan or destroy the Crack?
