Crack tube socket compatibility - quick question
Pluck · 4062
Offline Pluck
on: July 03, 2012, 11:07:08 AM
Hi all - quick question for you.  Do you know if the CMC Teflon tube sockets are a direct swap-out for the stock sockets that ship with the Crack?  Failing that, do you know of any direct replacements?
Thanks in advance.
Offline Noskipallwd
Reply #1 on: July 03, 2012, 06:54:21 PM
Hello pluck, I used the Teflon sockets in my Crack. I also used the pcb adapters for easier soldering to the pins. I used the sockets from parts connexion, but you can get them from the tube store and fleabay as well. HTH.
Cheers,
Shawn
Shawn Prigmore
Offline Pluck
Reply #2 on: July 03, 2012, 08:43:33 PM
Cheers,
Shawn
Thanks Shawn - were they a direct swap-out or did you need to modify the top-plate or anything to get them to fit?
Thanks.
Offline Noskipallwd
Reply #3 on: July 04, 2012, 05:51:43 AM
Pluck, no modification of the top plate was required, the screws line up fine, I put a couple of gold colored tube socket mounts on the top plate simply for looks. The pcb's have pin numbers on them but I still wrote them on the plate in marker just to be sure.
Cheers,
Shawn
Shawn Prigmore
