Russian Cap Identification
Thoburn · 6036
Offline Thoburn
on: July 17, 2012, 03:21:38 PM
I was given a couple capacitors that are suppose to be Russian teflon. They are about an inch in diameter and about 2 inches long. The case appears to be aluminum and the ends appear to be white plastic or teflon. The leads appear to be silver or silver plated. The only writing looks like the following:
(a schematic symbol for a capacitor and then a diamond shape)
(a greek symbol)T-3
OilMK(a greek symbol)
+- 5%(a delta symbol)
600B
9201
and the other one:
(a greek symbol)T-3
600B
9106
Does anybody recognize these cap? If so, what are its voltage and uF?
Thanks !!!
Dynavector DV-20X2L > VPI Scout II > Musical Surroundings NovaPhonomena
Mac Mini > USB DACiTx
Stereomour > Lowther Medallion DX4 and Rythmic Subs
Monster Power HTS3600
Reply #1 on: July 18, 2012, 12:48:07 AM
Sounds like KK Teflons.  They are 5% tolerance and 600 Volts.  Russian alphabet has no V.
I would, however, expect an "FT-?" on them for Teflon caps.  If the Greek symbol was Phi, Ф, that is the F in "FT-3".
Here is a link:
http://www.diytube.com/phpBB2/viewtopic.php?t=898
And in Russian (my brother speaks Russian):
http://sovietsouvenirs.com/FT.htm
« Last Edit: November 02, 2012, 03:13:19 AM by Grainger49 »
Offline Thoburn
Reply #2 on: July 18, 2012, 03:46:28 PM
That's it. ФT-3
Offline Thoburn
Reply #3 on: July 21, 2012, 12:48:28 PM
After much head scratching and reading through the web pages listed above (and working with a magnifier) I think this is what I have:
ФT-3
0,1 MKФ
+- 5%
600B
Which means large military grade teflon 0.1 uF plus/minus 5% and 600 volts. I have two. They are about the size of a D-cell battery. Now I have to figure out what I will use them for.
There is a number at the bottom of the label. One is 9106 and the other is 9201. I have to assume that the number is a batch id of some kind.
Reply #4 on: July 21, 2012, 01:27:52 PM
Yup, that is it.
A 0.1uF makes a good interstage capacitor in a Paramount 300B or Stereomour.  It could be used for a bypass in anything that needs 600V caps.
« Last Edit: July 22, 2012, 02:45:42 PM by Grainger49 »
Offline galyons
  • Geary Lyons
Reply #5 on: July 22, 2012, 01:55:55 PM
Date of manufacture... June 1991 and January 1992.  Great caps, BTW!!!
Geary
Reply #6 on: July 23, 2012, 03:23:05 AM
Ah, Ha! I might have known that but forgot it.  Thanks for the information!
« Last Edit: November 02, 2012, 03:14:21 AM by Grainger49 »
Offline Thoburn
Reply #7 on: July 23, 2012, 03:23:24 PM
Geary
Cool! Thanks for the info. I have Jupiter HT caps in my Stereomour. There is not much room, but maybe I could stuff the KKs in there somewhere. I will have to go read up on the cap burn in threads.
