Current status
Doc B. · 53224
Offline debk
Reply #30 on: January 08, 2013, 12:08:29 PM
Very nice!
Looking forward to building one
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline Demsy
Reply #31 on: January 08, 2013, 01:59:39 PM
Looks very nice! My only concern is the way the two caps near the pots are fixed to the baseplate, will the double face tape withstand the higher temperature of the baseplate once the amp is running?
Offline earwaxxer
Reply #32 on: January 08, 2013, 02:04:38 PM
Thats quite a kit! - I bet it sounds fantastic!
Eric
Reply #33 on: January 08, 2013, 02:23:06 PM
We have used these ny-tie holddowns on many kit chassis panels over the past 18 years without a problem.
Offline corndog71
Reply #34 on: January 08, 2013, 02:53:59 PM
Whoa!  That looks intense.  And awesome!
Rob
Offline xcortes
Reply #35 on: January 09, 2013, 01:38:32 AM
Awesome!
Xavier Cortes
Reply #36 on: January 09, 2013, 04:14:49 AM
Can I ask how tall the amp is?  In other words, how much vertical clearance would a rack eed to have for this?
Jim
Reply #37 on: January 09, 2013, 04:24:20 AM
Jim
Same as Paramount, 4" base plus 6" 300B, total about 10". I'd leave another 2" for cooling air flow around the tube, but the tube is run at relatively low dissipation so you could compromise on that a bit.
Offline johnsonad
Reply #38 on: January 09, 2013, 04:30:15 AM
Jim
Come on Jim, you know you want one! :)
Reply #39 on: January 09, 2013, 05:17:37 AM
Paul -- thanks -- 10" is the max shelf clearance on my rack, so I'd have to check out if my TT could go in that space and the pre on top.  Still pondering...
Hey Aaron, you're right! :-)
I've got to take some time to heal first then I can regroup and plan the next steps.  Looks like Dowdys will be coming next week.
Offline xcortes
Reply #40 on: January 09, 2013, 05:51:35 AM
It looks like one could enlarge the transformer holes to add an extra set of those nice Neutrik rca jacks.
Have the caps values been defined? What are types the stock ones?
Xavier Cortes
Reply #41 on: January 09, 2013, 07:06:29 AM
Hmm, I suppose you could enlarge those holes if you wanted.  Getting everything perfectly aligned by hand drilling can be frustrating.  Standard insulated gold RCA jacks should fit in those holes.
The caps are 10uF/250V stock.  Two will dominate the sonics of the single ended outputs, and all four the balanced output.  200V is a sufficiently high voltage rating for these caps.
Reply #42 on: January 09, 2013, 07:33:01 AM
By the way that cap value was arrived at empirically by measuring bass response with cap values ranging over about 1uF to 20uF. Anything below 10uF was where we saw some bass roll off into lower impedance loads.
Offline xcortes
Reply #43 on: January 09, 2013, 07:53:14 AM
A pair of Auricaps at Percy will cost 65.
Xavier Cortes
Reply #44 on: January 09, 2013, 08:44:31 AM
I plan to try some Audiocap film and foil caps next week. Right now I am experimenting with rearranging the positions of the drivers in my speakers after a listening session on Friday. Some new, slightly lower seating seemed to make the image kind of high in the room. I have to redo time alignment and trim levels, then we will do some comparison of the stock metallized caps vs. Audiocaps.
