Stereomour Build
marantzfan · 8150
Offline marantzfan
on: October 30, 2012, 09:24:46 AM
Well, I will be joining the bottlehead owners club soon, I ordered a Stereomour last week and am getting excited about the upcoming build.  As always, that means I have some questions.
1. What kind of paint works best for the transformer end bells?
2. Would Jantzen Z-Series capacitors be a noticeable upgrade from the stock Solens caps?
3. Any suggestions on stain for the wood frame to match the color of a Linn LP12 Afromasia plinth?
I'm sure once the kit gets here and I get started there will be much more to come.  :)
Heck, I haven't even gotten started yet and I'm already looking at the Eros.
BeePre, Paramounts 1.1, Eros, Thorens TD-124/AudioMods Tonearm/Ortofon 2M Black, IFI Micro Idsd, HQPlayer,  Altec 604-8G Duplex/620 Cabinets/Markwart Crossovers
S.E.X. 2.1, AKG K701
Reply #1 on: October 30, 2012, 10:04:46 AM
I like to paint or powder coat the transformer covers with a finish that is not smooth, as those parts tend to take a bit of a beating, and a textured or wrinkled finish takes the abuse better.
I've used Jantzen caps plenty of times in various builds, though mostly because they tend to have higher voltage ratings.  From a construction point, both the Jantzens and the Solens are metalized polypropylene caps (doesn't mean they don't sound different).
Stain matching is a pain, I'd buy the closest 3-4 cans at your local big box HW store, then test them on the back of one of the base pieces.
Offline marantzfan
Reply #2 on: November 29, 2012, 04:23:08 AM
Ok, my kit came in two days ago and last night I got started on it.  After about 2.5 hours I'm up to page 32 which is where it's time to mount the PT, so now it's time to figure out what I'm doing with the paint/powder coat so I can move forward.
I think I am going to go with gloss black paint as I don't really want to wait to get to get it powder coated although I do think that would be the best route.  My question for now is how do you paint the casings on the chokes next to the PT?  Do they come off somehow or do you just mask around them?
Reply #3 on: November 29, 2012, 06:10:44 AM
Don't try to take them apart. Just mask them off.
Offline marantzfan
Reply #4 on: November 29, 2012, 06:53:22 AM
Thats kind of what I figured just looking at it but I wanted to make sure.  Looks like I should do some sanding first then primer and paint.
Reply #5 on: November 29, 2012, 06:58:31 AM
Sometimes the varnish that is used on the transformers gets a little drippy on top. I use a rag and some acetone and rub the top vigorously. That will usually clean the varnish off and leave a clean surface.
Offline marantzfan
Reply #6 on: November 29, 2012, 07:00:34 AM
Awesome, that will make things alot easier.  Thanks again.  Time to get painting tonight after work.   ;)
Offline marantzfan
Reply #7 on: December 11, 2012, 05:47:34 AM
Well, I got it all put together and my voltage checks were good so I powered up and listened to it last night.  This amplifier sounds really nice but for some reason the left channel will cut out, almost like its not making a good connection with the socket.  If I turn the amplifier off and reposition the tube and turn it back on the left channel will play for a while and then cut out again.
What's going on here?
Reply #8 on: December 11, 2012, 06:08:01 AM
Rewet the solder joints around that socket.
Offline marantzfan
Reply #9 on: December 11, 2012, 06:15:51 AM
Roger that.  I'll do that tonight and report back.
BTW, not sure if I mentioned it earlier but this kit was an absolute pleasure to put together.   :)
Offline marantzfan
Reply #10 on: December 12, 2012, 07:31:42 AM
Hmmm...
Well I rewet all joints at the socket and around it.  BUT, I don't think I properly diagnosed the problem before.  Although the first time it was the left channel that would cut out, now it seems that either the left or right will cut out.  If I touch the metal plate both channels play just fine.  Grounding issue?
BTW, here is a picture of it.
« Last Edit: December 12, 2012, 07:34:10 AM by marantzfan »
Reply #11 on: December 12, 2012, 07:38:05 AM
Check the connections from the 12AT7 to the volume control, and from the volume control to the selector switch. Sounds like it might be a missed or cold solder joint.
By the way, looks really nice!
Offline marantzfan
Reply #12 on: December 16, 2012, 09:38:37 AM
I have checked and reflowed every joint at the 12at7, the volume control, the selector switch, the left 2A3 socket, actually pretty much everything on the left side.  The problem remains in fact it seems to have gotten worse.  I don't know what to do now.
Reply #13 on: December 16, 2012, 09:43:00 AM
Can you post a shot of the underside of the chassis?
So you get 0 sound, then if you touch the plate everything comes back?
When you touch the plate, are you tapping on it, or just ever so gently touching it with your finger? (Is there a difference between the two?)
Offline marantzfan
Reply #14 on: December 16, 2012, 09:44:40 AM
The right channel will cut in and out; if I touch the top plate (with a little pressure) it will bring it back when it cuts out.  The left channel now just seems to be out.
« Last Edit: December 16, 2012, 10:02:01 AM by marantzfan »
