Quickie Capacitor Question
Cary · 11115
Offline Cary
on: November 12, 2012, 02:28:22 PM
I am thinking of replacing the stock 2.2uf cap on my Quickie with the Dayton 1% metallized poly cap of the same value. Will there be a difference in sound quality?
Offline earwaxxer
Reply #1 on: November 12, 2012, 02:35:36 PM
There may be an improvement. You have to try it and see. I would go higher up the totem pole on that cap IMO. It doesnt hurt to try though! I'm not sure where Dayton gets their caps. You tend to get what you pay for in caps. Let us know what you think!
Eric
Reply #2 on: November 12, 2012, 03:00:03 PM
Offline corndog71
Reply #3 on: November 12, 2012, 04:29:45 PM
For a more neutral sound I recommend these:
http://www.soniccraft.com/sonicaps.htm
For a warmer yet still detailed sound try these:
http://www.madisoundspeakerstore.com/esa-cap-630vdc/claritycap-2.2-mfd-esa-range-polypropylene-caps/
For jaw-dropping dynamics and clarity try these:
http://www.madisoundspeakerstore.com/mr-cap-630vdc/claritycap-2.2-mfd-mr-range-polypropylene-caps/
I didn't like the Daytons or Jantzens I've tried but go ahead and try them.  Relatively speaking caps are cheap and easy to swap.
Rob
Offline STURMJ
Reply #4 on: November 12, 2012, 06:20:09 PM
I have 100uf datyons in one of my cracks, and i have bee very impressed with them.
Offline corndog71
Reply #5 on: November 13, 2012, 10:44:46 AM
Are you using them in the power supply or as output caps?
Rob
Offline the dude
Reply #6 on: November 14, 2012, 04:49:44 AM
Not a hijack but a contribution
Is Elna Silmic considered foul language here?
Its what I have been using there.
I have wanted to try a polystyrene or other . . .
Maker of fine true ribbon loudspeakers and modifier of everything. . .
Offline earwaxxer
Reply #7 on: November 14, 2012, 05:29:51 AM
I like the elna silmic. Its electrolytic though. Films tend to be better sounding.
Eric
Offline the dude
Reply #8 on: November 15, 2012, 04:43:20 AM
I have russian 200nf/500nf polystyrenes and could parallel to get the 'z'. Would that be too many to fit and too many to sonically be worth it anyone think?
A 2.2 uf polystyrene cap is hard to come by, I have heard good things about solen and ceramic type caps...
Don't have those on-hand tho...
Offline earwaxxer
Reply #9 on: November 21, 2012, 05:46:35 PM
Its hard to know with using small value bypass caps. They could help, or be worse. If I were to use bypass caps I think I would go with teflons.
Eric
Offline bmwr75
Reply #10 on: November 24, 2012, 11:28:06 AM
Here's what I would try:
https://www.solen.ca/pub/index.php?catalog=description&nodiapo&id=1342&recherche=&numRows=&manufacturiers=&niveau1=1&niveau2=3&niveau3=27&s1=1&s2=&s3=&s4=
I assume the 2.7 uF Solen caps are the ones on the outputs (my Quickie shipped this week I think).  What size are the two blue electrolytic caps?
Reply #11 on: November 25, 2012, 08:15:19 AM
If you got 2.7uF Solen caps, are they white by chance?
If so, you got an unintentional upgrade, those are outstanding caps, better in my opinion than any metalized cap I have tried...
The caps that I would consider possible upgrades from there would be the film/foil V-caps, the Audio Cap PCU, and the Jensen options.
Offline bmwr75
Reply #12 on: November 25, 2012, 08:54:04 AM
Yes, I ordered white 2.7uF caps from Quebec.
Reply #13 on: November 25, 2012, 09:17:13 AM
Ah, awesome choice!
The electrolytics are 1000uF/35V, but anything above about 50uF/5V will be OK.
Reply #14 on: November 26, 2012, 04:07:51 PM
Just curious, what's the usable range for the output coupling caps?  Assume going into a stereomour or s.e.x. with a 1 meter or less interconnect.
Jim
