Resistance Check Questions
networkn · 13855
Offline networkn
Reply #15 on: January 07, 2013, 03:08:00 PM
How about the wires that leave B3/B6?
 :D Oops, B6 connected to 10U not 9U as it's supposed to be. I feel pretty stupid now.
Reply #16 on: January 07, 2013, 03:24:56 PM
Good stuff, remeasure 6 and 10 after the correction and let us know if the voltages settle.
Reply #17 on: January 07, 2013, 03:38:19 PM
Nope, not at all. Everyone makes mistakes. My philosophy is don't make a mistake, never learn s**t. And I have the track record  (and enough metal parts in my body - somewhere around 20 or 21 not counting fillings and crowns) to prove that I practice what I preach! The only people who should feel stupid are the ones who have a problem with their kit assembly and don't ask for some support here. Congrats on sorting it out!
Offline networkn
Reply #18 on: January 07, 2013, 10:44:48 PM
Thanks. Well everything was going swimmingly, the resistance checks were much closer to what I expected and I was all the way to A8 and that wasn't right, then I noticed there was no light from that LED (Connected to A8).
I think I must have shorted it accidentally perhaps?
6 and 10 are still giving me (identical) unexpected results. They should be Zero and they are ranging constantly between 30-40V by the looks.
Looking around I see a few people talking about accidentally shorting the A8 LED is that likely? Is there a way to test?
Not sure if I can source that locally, confirming this is the model number? HLMP-6000
Reply #19 on: January 08, 2013, 08:28:25 AM
If the LED on A8 isn't lighting up, how is the voltage at terminal 1? (It should be high)
Eileen can send you a replacement HLMP-6000 if you burned one, they tend not to short.
Offline networkn
Reply #20 on: January 08, 2013, 10:39:08 AM
Yup Terminal 1 is now at 140v not the 90 it was earlier in my tests.
I'll see if I can source one locally.
Reply #21 on: January 08, 2013, 11:49:58 AM
If your meter has a diode checker, you can check the LED.  Sometimes the striped end doesn't solder all that well on the center lug of the 9 pin socket.
You won't find the HLMP-6000 in most hobby electronic stores, it is kind of an unusual LED.
Offline networkn
Reply #22 on: January 08, 2013, 12:01:41 PM
Hmm pity! Is there a substitute I could consider that might be more easily sourced without the delay of shipping replacements from the US to NZ?
Offline networkn
Reply #23 on: January 08, 2013, 12:03:18 PM
Perhaps for an extra cost BH could sell a $10 kit that contains spares and recommend it to international buyers at the time of their initial purchase, of the most commonly damaged or faulty components (I broke this I believe so I am not suggesting otherwise).
Reply #24 on: January 08, 2013, 12:20:24 PM
We think offering free replacements works a little better, most of the time these things hold up pretty well.
A 475 ohm 1/8 watt resistor will work in place of the HLMP-6000 in the Crack circuit. (470 Ohm is OK too)
Offline networkn
Reply #25 on: January 08, 2013, 12:21:46 PM
Ok what about this?
http://newzealand.rs-online.com/web/p/visible-leds/1934746/
It was suggested by an electronics savvy friend of mine as a possible replacement. LED would suit me better than a resistor as it's nice to be able to see if it's actually working.
Also I can find locally a 470ohm 1/4 watt I presume that isn't close enough?
Also a diode stops current flowing the wrong way too I presume, is that a concern with a resistor in place?
« Last Edit: January 08, 2013, 02:41:02 PM by networkn »
Reply #26 on: January 08, 2013, 05:21:29 PM
The HLMP-6000 is about the last "standard red" LED still in production. Modern red LEDs are brighter and not as deep a red, both of which cause it to drop (slightly) more voltage. You can certainly try another red LED - see if you can find one that is NOT "high-intensity". Monitor the terminal 1 voltage; if it's not too high then what you have will work. Even if it's a bit out of spec, it will work while the replacement wends its way across the ocean ...
Offline networkn
Reply #27 on: January 09, 2013, 02:17:56 PM
Well I have a resistor I'll solder tonight and hope like crazy that's the last of the issues.
Offline networkn
Reply #28 on: January 09, 2013, 10:30:17 PM
Hi There!
I have posted my final voltage checks, I am really only wanting to check that 6 and 10 are ok being variable between 15-40mV
1) 90 | 84
2) 170 | 161
3) 0 | 0
4) 170 | 160
5) 90 | 82
6) Wildly going all over the place around 14-40MV
7) 100 | 103.9
 0 | 0
9) 100 | 103.9
10) 0 | 14-40MV
11) 0 | 0
12) 0 | 0
13) 170 | 160
14) 0 | 0
15) 185 | 182
20) 0 | 0
21) 206 | 204
a1) 90 | 80
a2) 0 | 0
a3) 1.5 | 1.5
a4) 0 | 0
a5) 0 | 0
a6) 90 | 84
A7) 0 | 0
a8) 1.5 | 1.6
a9) 0 | 0
b1) 90 | 84
b2) 170 | 160
b3) 100 | 104
b4) 90 | 81
b5) 170 | 160
b6) 100 | 104
b7) 0 | 0
b8) 0 | 0
Thanks for all your help.
Reply #29 on: January 10, 2013, 05:05:58 AM
You're good to go.
14-40mV is 0.014-0.040V, which is nice and low.
