Isolation tweaks
Doc B. · 25696
on: February 14, 2013, 12:29:31 PM
Hey, it's a DHT preamp. We knew that microphony was a potential issue when we came up with the design. So I am starting a thread in which we will offer some ideas for isolation and damping.
After a little experimentation this week I have an initial tweak - 1-1/4" 30D Sorbothane hemispheres under each of the four corners of the chassis. I got some off ebay for $17 for the set. Tried smaller and higher durometer ones. They were not as effective, this one seems the sweet spot for the weight of the preamp (~12.4 lbs) and the dimension of the wood base panels. They should help to keep the floor/rack/shelf borne vibration out of the preamp chassis and they look pretty good.
A second and really cheapass approach that is very effective is to put each corner of the wood base on a folded piece of the larger bubble size bubble wrap. We folded four 6" squares over twice to make four roughly 2x2, four layer pads. This looks very lotech/dumpster diver/trailer park if that is the look you are going for.
Based upon a little experimentation yesterday I am also looking into an interesting tube damper concept, that I will share more about once I have given it a try.
Reply #1 on: February 19, 2013, 02:43:13 PM
My tube damper test subject showed up today. Seems to help.
Reply #2 on: February 19, 2013, 02:47:07 PM
And here is a close up of the amount of compression of one of the 30D 1-1/4" Sorbothane hemispheres on the base. These really do work well to cut down vibration from the shelf.
« Last Edit: February 19, 2013, 02:49:37 PM by Doc B. »
Reply #3 on: February 20, 2013, 01:56:18 AM
Dan, your tube damper looks like the ring off of a giant condom.  What is it?
Offline dbishopbliss
Reply #4 on: February 20, 2013, 03:51:09 AM
That condom looks sort of small to me.  :-)
David B Bliss
Bottlehead: Foreplay I, Foreplay III, Paramour I w/Iron Upgrade, S.E.X. w/Iron Upgrade
Speakers: FE127E Metronomes, Jim Griffin Jordan/Aurum Cantus Monitors, ART Arrays
Other: Lightspeed Attenuator, "My Ref" Rev C Amps, Lampucera DAC
Reply #5 on: February 20, 2013, 04:52:26 AM
I need to do a little more research before I share the details.
Reply #6 on: February 20, 2013, 05:57:28 AM
David,
I guess it depends on which tube it is on.  On my 76 drivers it is small, on the 300B a good bit larger.  But I've never seen the roll/ring that thick.
« Last Edit: February 21, 2013, 12:48:37 AM by Grainger49 »
Offline saildoctor
Reply #7 on: February 20, 2013, 11:34:32 AM
I use round welded stainless and bronze rings all the time at work.  Maybe plasti-dipped they could work as dampers?  Or maybe as is?  Hmm.. i should try this out.
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
Offline ssssly
Reply #8 on: February 21, 2013, 12:16:36 AM
I thought it looked like one of those rings you see at the carnival. Where you have to toss it over a bottle neck to win a stuffed animal.
Could start a new fad Doc. The bottlehead ring toss.
Reply #9 on: February 21, 2013, 04:59:14 AM
Ah shoot, I've been figured out! The other part of the package is an equipment rack made of giant stuffed animals.
4krow
Reply #10 on: February 22, 2013, 06:25:03 PM
Those kind of Sorbothane work good for me too, but a word of caution, they tend to be sticky, and most surfaces will show marks where they have sat. If sitting on top of a painted surface, it can really be bad, to the point that paint will have permanent marks. Sometimes, I use Scotch tape on the feet to provide a barrier. In spite of this problem, I still use Sorbothane feet for a lot of my components.
Reply #11 on: February 22, 2013, 07:27:50 PM
Very good point. They are really sticky, to the point where some smaller ones would stay stuck to the shelf when I pulled the preamp up! Tape is a good idea. I was thinking maybe talcum powder or pledge furniture polish, but those probably wouldn't last very long.
Offline ssssly
Reply #12 on: February 23, 2013, 01:27:15 AM
My trick for those sticky Sorbothane balls is a cutting board.
Whatever those super thin, white cutting boards are made out of is actually a pretty decent dampening material (at least the ones they sell at the Japanese dollar store). And if you have a hole saw around the size of the Sorbothane ball you can make a nice little coaster out of it to protect your stuff.
Offline RPMac
Reply #13 on: February 23, 2013, 02:04:45 AM
What about the felt furniture pads on the bottom of the sorbothane pads?
4krow
Reply #14 on: February 23, 2013, 04:49:59 AM
Ya know, I actually did try that. Funny thing was, they wouldn't stay on. For some reason, the chemistry just wasn't there.
