Completed sex kit: No sound from right channel
mpent · 20517
Offline mpent
Reply #15 on: April 26, 2013, 04:47:49 AM
Hmmmm...I did receive the C4S upgrade but did not open it. I guess I should open it up and see if the 1270 is in there. So overall, will resoldering the pins you mentioned and putting in the proper resistor at pin 6 rectify my issue?
Michael
Offline mpent
Reply #16 on: April 26, 2013, 06:55:20 AM
So the C4S parts pack does not have the 1.27k resistor in there and what was supposed to have been stocked in the sex kit were 2 237ohm resistors. I need to obtain these to swap them out. But Paul, the parts list for the C4s upgrade does not contain 237 ohm resistors just 499ohm and 150kohm resistors so I'm confused.
Michael
Offline mpent
Reply #17 on: April 26, 2013, 07:24:30 AM
Ok. I'm an idiot. I have the 1.27 resistors. I put them at the wrong terminal. Instead of the 249's I got 237's but Dan says that's fine. So I have to swap places with the 1.27 and 237.
Michael
Reply #18 on: April 26, 2013, 07:57:15 AM
I misunderstood you on the phone. The 237 ohm resistors are very different than the 249K ohm resistors. We will send replacements for both.
« Last Edit: April 26, 2013, 08:00:37 AM by Doc B. »
Offline mpent
Reply #19 on: April 26, 2013, 08:00:49 AM
Oh, ok. Thank you much!
Michael
Reply #20 on: April 26, 2013, 11:22:06 AM
Apologies for my confusion - too many kits and versions, so I mis-remember the values.
There is a 220 ohm grid stopper at pin 4 on the circuit, which has (I think) been replaced with the 237 since we have a large number of them on hand for many kits.
There is a 150K 2-watt resistor on pin 5; it's larger than the others.
There is a 1270 on pin 6.
The C4S kit has 499 ohm resistors and 150K 2-watt resistors - yes, a second set of the latter - it's easier than trying to re-use the old ones!
Offline mpent
Reply #21 on: April 26, 2013, 11:44:01 AM
Ok, so I got replacement resistors coming in the mail. That being said, is it possible that once the out of spec voltages are corrected that my issue of no second channel and scratchy left channel will be resolved?
Michael
Reply #22 on: April 26, 2013, 12:07:02 PM
So far we have addressed one channel's driver, pins B4-5-6. There are probably similar problems with A4-5-6 - at least the wrong 1270 ohm resistor. I can't figure out why the plate voltage A6 is correct but the cathode A5 is not, so check and fix all those resistors and we'll see what problems remain.
Offline mpent
Reply #23 on: April 26, 2013, 12:41:36 PM
Ok, sounds good. Thanks again!
Michael
Offline mpent
Reply #24 on: April 30, 2013, 07:28:31 PM
Ok. Corrected placement of 1.27 resistors and installed 249ohm resistors. Went back through resistances and voltages out of spec and everything now within range. Left channel seems to be working properly. Output is clear and strong.
However, still no sound from right channel. Checked wiring at output transformers. Resoldered some connections at transformers and headphone jack but still nothing. Removed left channel from operation and turned volume all the way up and right channel has very dim, scratchy sound. Any guidance would be greatly appreciated.
Michael
Michael
Reply #25 on: May 01, 2013, 04:03:15 AM
If the voltages on the tube pins are within the normal range, then the tubes are working correctly and the problem is at either the input or the output.
With gain all the way down, listen very closely (headphones are easier to hear with if you have some; otherwise put your ear right at the speaker, in a quiet room if necessary). If both channels produce the same tiny level of hiss and hum, then the problem is probably at the input or gain control. If you can hear some left channel but the right is completely silent, then it is at the output or the output transformers.
Offline mpent
Reply #26 on: May 01, 2013, 07:56:26 AM
Ok....slight hiss (wow this amp is quiet) in both speakers.
Michael
Reply #27 on: May 01, 2013, 11:13:00 AM
Check your input jacks for a solder bridge from the center post to the outer shell.
Offline mpent
Reply #28 on: May 01, 2013, 01:00:54 PM
Yahooooooooooooo!!!!!! That did the trick!!!!!! I sured up the jacks with additional solder.  Thank you so much for all your assistance and patience!!!
Michael
Reply #29 on: May 01, 2013, 02:34:10 PM
Excellent! Enjoy!
