Transformer for Foreplay II
Cary · 5910
Offline Cary
on: July 14, 2013, 08:06:32 AM
Hello,
I need a transformer for my Foreplay II. What are my options, does Hammond or Allied make one? If so what is the product #?
Thank you,
Cary Chin
Offline galyons
  • Geary Lyons
Reply #1 on: July 14, 2013, 08:30:03 AM
Allied Electronics  model 6K27VF is an exact replacement.
TRANSFORMER, PRI:110-120V, 60HZ, 125VCT@15DCMA, 6.3V @.6a
http://www.alliedelec.com/search/productdetail.aspx?sku=70009000
Allied Electronics  model 6K1VF is an "upgraded current" replacement.  May allow for some tube rolling variations not possible with the  original.
TRANSFORMER, PRI: 110-120V: 60HZ, 250VCT@25DCMA, 6.3V @1.0A
http://www.alliedelec.com/search/productdetail.aspx?SKU=70008994
Cheers,
Geary
Offline Natural Sound
Reply #2 on: July 14, 2013, 09:14:16 AM
Cheers,
Geary
Are you sure? The secondary voltages are different, 125VCT vs. 250VCT
Offline galyons
  • Geary Lyons
Reply #3 on: July 14, 2013, 09:24:43 AM
Cheers,
Geary
Yes, the 6K1VF will give more B+ and filament current to work with so you try tubes such as the 12BH7.
Cheers,
Geary
Reply #4 on: July 14, 2013, 10:44:41 AM
The Foreplay has a long history; hopefully the following will help clarify some parts:
Foreplay I used a 12.6vAC heater supply, and a 125v HV winding with a full-wave bridge rectifier (four diodes).
Foreplay II used a 6.3vAC heater winding, and a 125v HV winding with a full-wave bridge rectifier (four diodes).
Seduction used the PT-1, which was also used by some eXperimenters to upgrade their Foreplays. That transformer has a 6.3vDC heater supply, and a 250vCT HV winding, using a full-wave CT rectifier (two diodes).
Foreplay III used the PT-3 with a 6.3vDC heater supply and dual, paralleled 160v HV windings, which used a voltage doubler to obtain a high voltage which was regulated to 150v with a gas regulator (0D3).
Extended Foreplay used the PT-3 with 6.3vDC heater supply, and the dual 160v windings fed dual-mono fullwave bridge rectifiers (four diodes per channel).
Offline Cary
Reply #5 on: July 15, 2013, 05:26:06 AM
Thank Paul and everyone, I will be ordering an Allied 6K27VF for my Foreplay II.
Cary
Bottlehead Ambassador
