Reduction Voltage Check
M42 · 5579
Offline M42
on: July 23, 2013, 04:18:28 PM
Hi all,
I have just completed my Reduction...all resistance and voltage checks were spot on, with the exception of one voltage measurement. When I started the amp for the first time both tubes lit within a few seconds and all led's lit. The manual states terminal 15 should read zero volts...I consistently measure 99 volts. The amp seemed to run fine during the voltage test...nothing seemed hot, no smoke etc. I have checked my wiring against the manual, everything looks right. I will attach a photo once I get it resized.
I have not yet connected the amp to my turntable and Crack headphone amp to test it further. Any advice would be appreciated.
Jeff
Jeff Hullin
Stereomour(2A3), Eros, Crack/Speedball, Thorens TD160 MKII, Grace F9E, Sennheiser HD600's, Frugelhorn 3's, DIY 8" Subs.
If at first, the idea is not absurd, then there is no hope for it.
Reply #1 on: July 23, 2013, 04:21:26 PM
Hello Jeff,
That looks like an error in the voltage checks.
16 is 0V
15/14/13 will be 70-90V
Offline M42
Reply #2 on: July 23, 2013, 04:26:51 PM
Hi Paul,
Terminal 16 reads 0 volts...13, 14 and 15 read 99.8, 99.7 and 99.7 respectively. So it appears I'm ok to connect the amp and see how it runs?
Many thanks,
Jeff
Jeff Hullin
Reply #3 on: July 23, 2013, 04:39:32 PM
Indeed, enjoy!
(We'll get that voltage issue revised in the manual, thanks for letting us know!)
Reply #4 on: July 23, 2013, 05:50:22 PM
Manual update complete.
