how is Quickie easy to build?
charger · 22408
Offline Bonzo
Reply #60 on: August 04, 2013, 07:34:25 PM
Off topic - Italian dudes, where in Italy? I hope to be in Rome and Syracuse this fall ...
Hi Paul! I'm from Venice and I moved to Milan in 2008.
Bisogna avere orecchio!
Offline charger
Reply #61 on: August 04, 2013, 09:08:55 PM
Hi Paul , I am from Tuscany
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Reply #62 on: August 05, 2013, 08:08:55 AM
Well maybe another trip then ... It's been nearly 40 years since we saw Venice and Florence but I still want to attend a performance at La Scala some day!
Offline charger
Reply #63 on: August 05, 2013, 08:45:01 AM
you are wellcome !!
Offline Bonzo
Reply #64 on: August 05, 2013, 09:20:51 AM
Why not La Fenice + La Scala?
 ;D ;D ;D
Nice journey anyway! Have fun!
Offline charger
Reply #65 on: August 06, 2013, 01:11:26 AM
there is still a little bit hum on the right channel , how can i quite it at all ??
4krow
Reply #66 on: August 06, 2013, 04:22:29 AM
 I haven't followed your issue completely, but chances are that the Q is too close to another component, picking up hum on just one side. The other possibility is cabling/routing.
Offline charger
Reply #67 on: August 06, 2013, 05:20:11 AM
the him is really low , what do you mean for routing ?
thanx
4krow
Reply #68 on: August 06, 2013, 07:25:07 AM
  Well, my interconnect cables will sometimes pick up hum from nearby power cords, or even nearby equipment. I will try to get them away from such 'problems' by routing the interconnect a different path, so it is not so close to the offending cable/equipment. You might even try moving the interconnect cable around and listen for hum as you move it.  If that is not the problem, then let's look to the position of the Quickie itself. Is it close to another piece of equipment? I say this because you have hum in one channel only, and that indicates a possibility of one side of the Quickie being affected by the magnetic field of the offending component. My Quickie ha to be away from my amp at least 4 inches or the left channel will have a slight hum. Hum can be tricky to find. Rarely I have even found a component UNDERNEATH the affected unit! The shelf below. Out of sight, out of mind.
Offline corndog71
Reply #69 on: August 06, 2013, 07:34:22 AM
Have you tried swapping channels with the tubes?  If the noise moves to the other channel then you probably have bad tube.
Rob
Offline charger
Reply #70 on: August 08, 2013, 10:59:45 PM
thnk you all , I think the prolblem is the laptop pc cable i will check better but i think surely is it
thank you
