how is Quickie easy to build?
charger · 22280
Offline charger
on: August 01, 2013, 01:15:07 AM
Hi to everybody I am waiting for my Quickie to arrive soon , but i little bit worried about , will I be able to build it? can you tell me if is it really easy to build ?  thank you
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline adamct
  • Maxxximum CAPacity Crack
Reply #1 on: August 01, 2013, 01:17:24 AM
It is really easy to build. In fact, probably half of the manual doesn't even require you to use a soldering iron. It's just assembling the pieces, primarily by hand, with a final tweak from a screwdriver.
Offline earwaxxer
Reply #2 on: August 01, 2013, 04:07:53 AM
No worries! Its a perfect first kit. Great instructions make a huge difference. Follow them EXACTLY! It will work first time if you take your time and study the instructions and double check everything. Enjoy the process, no hurries, no worries!
Eric
Offline charger
Reply #3 on: August 01, 2013, 04:12:55 AM
ok thank you all , I am really exited to see how it sounds !!!
4krow
Reply #4 on: August 01, 2013, 04:33:33 AM
  I am anxious to hear what you think of it. Most of us are greatly impressed by it's performance.
Offline corndog71
Reply #5 on: August 01, 2013, 04:40:03 AM
The Quickie is about as easy as it gets as far as tube preamps go.  Plus, this forum will provide all the support you need to get it done.
What amp are you pairing it with?
Rob
Offline charger
Reply #6 on: August 01, 2013, 04:43:05 AM
i will pair it with an ALC0240 Abletec module , a class D amp
Offline charger
Reply #7 on: August 01, 2013, 04:44:28 AM
I will report for sure my impressions
Offline earwaxxer
Reply #8 on: August 01, 2013, 05:17:22 AM
I think it will sound great with the class D. When I first built my Q I was using an integrated T-amp. What I found was that the Q provided mush needed "drive" to the sound. It was like putting a turbo charger on it, plus better definition, clarity, timber - you name it.
Eric
Offline charger
Reply #9 on: August 01, 2013, 05:25:02 AM
yes i think they are well paired , Abletec modules  are really nice sounding , powerfully dynamic
Offline earwaxxer
Reply #10 on: August 01, 2013, 06:13:24 AM
That really gets me thinking... (That's dangerous!) - I might try to pick up muscular class D and see how it fairs next to my A/B amp with Q at the helm.
Eric
Offline corndog71
Reply #11 on: August 01, 2013, 06:17:42 AM
I have a ClassDAudio SDS-258.  250watts/ch.  It weighs about 50 pounds because I put in a 1000VA toroid!  Is that muscular enough?
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi576.photobucket.com%2Falbums%2Fss207%2Fcorndog642%2Fclassdaudio%2520amp%2Fd0a25c7b.jpg&hash=0fd84edeb803cf210a193c0920fa1a1308206fbf)
Rob
4krow
Reply #12 on: August 01, 2013, 06:29:29 AM
Eric,  We have found our long lost brother!
Offline earwaxxer
Reply #13 on: August 01, 2013, 07:41:29 AM
Hey Greg - yes I do believe Rob is a brother from a different mother! - hey Rob - ClassDaudio kits have been very tempting. How do you find their sound - withe the Q that is?
Eric
Offline corndog71
Reply #14 on: August 01, 2013, 07:56:13 AM
It sounds good.  Similar to NAD.  Good dynamics and has a nice easy warmth to it.  Definitely non-fatiguing.  My only complaint is that it's not as resolving as my tube amps.  It was fun to put together but now I mostly use it as a back-up when the valves go down.
Rob
