let's talk about tubes for Quickie
charger · 10820
Offline charger
on: August 04, 2013, 06:25:09 AM
which brand of tubes are better for the Quickie ?  which are less microphonic ?
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
4krow
Reply #1 on: August 04, 2013, 07:12:42 AM
 While these tubes seem to be microphonic by nature, I have found that Telefunken tubes have a bit less of the problem. I have only tried the originals and the Tel's so there may be other observations out there. I use Herbies dampers on the tubes as well.
Offline denti alligator
Reply #2 on: August 04, 2013, 07:58:26 AM
which of the Herbies dampers do you use?
- Sam
4krow
Reply #3 on: August 04, 2013, 08:40:24 AM
  I don't recall the model, but I went for the one that cost $13 ea. After reading through the website, I found that this damper had all of the benefits of their top of the line at that time, and was cheaper. The difference that I notice is small, but to be fair, I haven't listened very much yet, as the Quickie is getting remade. I am working on it today.
Reply #4 on: August 04, 2013, 08:44:55 AM
one of the these, I assume:
http://herbiesaudiolab.net/preamp.htm
what's the size of the Quickie tubes? 5/8" to 3/4"?
- Sam
4krow
Reply #5 on: August 04, 2013, 10:59:51 AM
   You are correct sir.
4krow
Reply #6 on: August 05, 2013, 04:38:52 PM
  One thing that I would like to mention about the Telefunkin tubes, is that near full volume, they have a lot of distortion. To be fair, I rather think that it might have to do with something else that I have done with the circuit. So far, I have changed the original volume control to a stepped attenuator, but I'm thinking that's not it. I have changed out output caps twice, and the problem has occurred with both caps. Other than those two things nothing much has been done. That is why I tend to think that these tubes might be the reason. Ok, now I have to switch back to the originals just to check.
Reply #7 on: August 05, 2013, 04:44:16 PM
You might measure the plate voltages with the Telefunken tubes installed, they might be a little higher than desired (which could cause earlier clipping).
Offline earwaxxer
Reply #8 on: August 05, 2013, 06:37:54 PM
Dont forget about the definitive reference for Q technology:
http://www.bottlehead.com/smf/index.php/topic,3491.0.html
IMOSSMS.  ;D
Eric
4krow
Reply #9 on: August 06, 2013, 01:33:01 PM
  Would this even occur if voltages and resistances checked out?
Offline earwaxxer
Reply #10 on: August 06, 2013, 01:50:57 PM
Distortion at high volumes (gain) I have not noticed before. I even took the volume control out and didn't notice any real change in distortion. In the end the pot sounded better than the digital volume control. Not sure why the tube is getting overdriven like that.
Eric
4krow
Reply #11 on: August 06, 2013, 04:58:31 PM
 Just a shot here. Would heater voltage have any effect?
Offline earwaxxer
Reply #12 on: August 06, 2013, 05:31:35 PM
Like too much? I use rechargeables so I'm always less than 1.5V. Experts can chime in here, but I dont notice any difference in sound as the heater batteries go low. I usually just hear one channel cut out when the voltage gets too low.
Eric
Reply #13 on: August 06, 2013, 06:14:21 PM
The Quickie has fairly limited output voltage capability. Into a high impedance load, clipping would be expected at 3.5vRMS with fresh batteries, 2.3vRMS at the end of battery life. For myself, I'd prefer to keep it below 1.0 volts to avoid audible coloration - but it depends a lot of what the meaning of "audible" is! For comparison, BeePre or Foreplay should put out 20vRMS before clipping.
If your amp/speaker combination needs more that 1vRMS peaks, Quickie can run into trouble.
4krow
Reply #14 on: August 06, 2013, 07:38:12 PM
  I will look into this tomm.
