Crack Amp/ plus Speedball builder?
sdell101 · 14501
Offline adamct
  • Maxxximum CAPacity Crack
Reply #15 on: August 07, 2013, 04:58:11 PM
I think there are multiple versions, depending on which attachments are included. I consider 16-22 awg a more useful range than 20-30 awg anyway.
Offline adamct
Reply #16 on: August 07, 2013, 05:04:14 PM
See here. They are in stock, and cheaper. FWIW, HMC Electronics sells absolutely AWESOME, serious-duty tweezers, that are dirt cheap, but incredibly well-built. I think they cost $6... Very useful.
Offline adamct
Reply #17 on: August 07, 2013, 05:08:51 PM
These are the tweezers.
Offline adamct
Reply #18 on: August 07, 2013, 05:12:03 PM
And if you ever decide to build a solid state amp (I recommend the AMB M^3), this is very useful, too.
Offline wolfetan44
Reply #19 on: August 07, 2013, 07:12:21 PM
I won't call it a direct quote, but much of the manual reads just like that.
As for wire strippers, see here: http://www.bottlehead.com/smf/index.php/topic,3279.msg40579.html#msg40579
Adam, you say 20-30awg strip, but this website says 16-22awg: http://www.mcmelectronics.com/product/22-3046  Am I looking at the wrong one or what? Thanks.
Adamct, could you answer this?:)
Offline adamct
Reply #20 on: August 07, 2013, 07:15:51 PM
I did. See above: "I think there are multiple versions, depending on which attachments are included. I consider 16-22 awg a more useful range than 20-30 awg anyway."
The "blades" that cut the insulation of the wires are modular. You can buy replacements, and different sets of "blades" will cut a different set of wire gauges. Since I find 16-22 a more useful range, I wouldn't hold out for the 20-30 AWG version.
Offline wolfetan44
Reply #21 on: August 07, 2013, 08:07:27 PM
I find 20-30 much more useful. Could I get a link for different blades?
Reply #22 on: August 07, 2013, 08:23:32 PM
There should be a factory authorized assembly service starting very soon. When the person is ready to take work I will announce the details.
Interesting, any thoughts on pricing?
I think that is one of the details I will announce when the person is ready to take work.
Offline adamct
Reply #23 on: August 08, 2013, 02:00:11 AM
It may only be the Stripmaster (non-Lite) that is available in a 20-30awg version. Ideal Industries has a chart with all the different versions available on their website. See here. The blades all start with LB-100x. The Stripmaster Lite seems to be available in a version that covers 16-22awg, or 24-30awg.
Offline Downhome Upstate
Reply #24 on: August 08, 2013, 03:39:45 AM
Sure! It's how I know Doc and the gang will be extra-motivated to keep me from electrocuting myself...
 ;D
Res ipsa loquitor   ;)
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Offline wolfetan44
Reply #25 on: August 08, 2013, 05:29:06 AM
You think it would be worth it to get both versions? I love making cables so I would definately use them:) where do I buy these also?
Reply #26 on: August 08, 2013, 06:28:04 AM
If you have successfully built cables (soldered, not crimped), then the Crack will be in your wheelhouse.  It is important to take your time and read every word in the manual, working as patiently as you need to in order to make your Crack look like the photos.
Offline adamct
Reply #27 on: August 08, 2013, 06:49:53 AM
I posted a link to the Stripmaster Lite from HMC Electronics above. I've found them to be excellent to deal with...
Offline dubiousmike
Reply #28 on: August 08, 2013, 10:33:33 AM
I've also seen these recommended and had been thinking of ordering a pair: http://www.newegg.com/Product/Product.aspx?Item=N82E16803001603&ParentOnly=1
Now, of course, you guys have me contemplating something 2.5x as expensive.
Mike M.
Reply #29 on: August 08, 2013, 10:37:26 AM
It seems the original poster has not posted back.  I sent a PM offering help, I haven't received a PM either.  He may have given up.
« Last Edit: August 08, 2013, 02:05:06 PM by Grainger49 »
