It does indeed appear that the photos on the bottom of p63 and top of p64 are actually from the phono version of the manual. Anything other than the wires called out in those photos can be disregarded.
Have you tried substituting some different cables between the playback head and the Eros? Rolled off treble and tipped up bass are basically the same thing, as there is a limit to the amplification factor of the Eros and thus all EQ is really only subtractive, i.e., there is no real bass boost, only mid and or treble cut. Hence the influence of a cable interaction that rolls off the treble can seem like it also boosts the bass. I don't mean to seem stuck on this point and I am certainly willing to look at every possible reason for the issue. But I have had to deal with this exact issue at more than one trade show where an exhibitor has used an Eros with a high quality cable of their own choice and complained that the treble was rolled off, only to find that when we changed to a different cable everything was fine.
I am also not familiar with the head in an RT707, so I can't know for sure if its impedance is a good match to the loading we provide. That loading has been optimized for heads we are familiar with - Technics RS1500, Otari MX-5050, Studer, Ampex ATR, Nagra T Audio, Flux Magnetics extended response. Those for the most part are around 200mH inductance and a load of around 75K to 90K seems to work well. It is possible that a different load impedance could help a bit, but without any specifications it would have to be a cut and try type of adjustment. It's possible to replace the input load resistor with a 100K or 250K trim pot wired as a variable resistor to make this adjustable.
Of course all of this is long distance speculation. To best solve the mystery a response curve of the preamp would be the first, best step.
OK we have discussed checking the EQ to make sure it is correctly wired and that the caps values are correct. We have discussed head to preamp interconnect cable and head loading. We have discussed possible coupling of hum from outside sources. It could also be a tube issue, though that is typically a problem in one channel, no both. Substituting a different set of tubes might give some information. Also, the output impedance of the Eros is about 3K. If the load it is running into is very low, like 3k or less, or if the cables from the Eros to the next piece of gear are very long that could have some influence upon the perceived bass performance, i.e. it could sound loose or rolled off on top. If the load is above 10K or so and the cables are under 2M long this is probably not the issue.
