A new project fell into my lap...
porcupunctis · 10077
Offline porcupunctis
  • 0D3
on: August 24, 2013, 08:38:28 AM
A young lady in my Trig class brought in an old record player a few days ago and asked if I could fix it.  I told her that I would take a crack at it.  When I opened up the case I was amazed by two things.  First, it is a very simple design and second, they schematic is plastered to the bottom of the case.
When I checked it out, I found that the whole thing was basically functional.  Motor runs, speed control, power and volume all to their thing but the overall volume barely overcomes the sound of just the needle in the groove.  It's not bad sound, just not much sound.
The tube tested bad in my TC-3 so I replaced it along with the filter caps (I had a few electrolytics laying around the 50/150 was replaced with a 47/450 and the 30/150 with a 33/450).  I then gave the potentiometer and socket a good dose of Deoxit and figured I was good to go.  When I tested it again there was only the slightest improvement in volume.  A little louder but not the way it should be.
My question now is this:  Could it be the Selenium Rectifier?  I could pull it out and test it but I'm not sure exactly what to look for.  Should it test exactly like a diode? or not?
So here is the player and the schematic:
Randall Massey
Teacher of Mathematics
Reply #1 on: August 24, 2013, 09:23:11 AM
All good ideas to start with.
Selenium is bad stuff, so you could get rid of it on general principles.  If the rectifier is bad you will have no or low voltage on the capacitors.
  • 0D3
Reply #2 on: August 24, 2013, 09:36:44 AM
I pulled the Selenium Rectifier out of the circuit and checked it with the ohmmeter.  I got 250K in one direction and 500k in the other.  That didn't seem like much of a diode, so I replaced it with a 1N4007.
With a new tube, new filter caps and new diode, the sound is stronger but it still has a long way to go.  The schematic shows a connection to pins "2-5" on the tube but pin 2 is clean like it's never had anything connected.
I'm now starting to suspect the output transformer as a possibility.  Not much else to check at this point.
Randall Massey
Offline galyons
  • Geary Lyons
Reply #3 on: August 24, 2013, 09:38:19 AM
Occam's Razor....check the stylus.
Cheers,
Geary
  • 0D3
Reply #4 on: August 24, 2013, 09:56:51 AM
Geary, good point.  Soooo, how do I actually "check" the stylus?  Is there an expected voltage I can check with the oscilloscope?  Do I need a microscope?
I think I've been staying in familiar territory while ignoring the obvious.
Randall Massey
Offline galyons
  • Geary Lyons
Reply #5 on: August 24, 2013, 10:40:19 AM
The stylus is replaceable.  There should be a conical nub at the end of the cantilever.  A magnified look will be helpful,
Although the cartridge suspension has likely hardened and effecting playback.
Since they were designed as a "system", output voltage was all over the place on old phonographs.  But you should see somewhere around 50-500mv. Wide range, I know, but don't know the spec's or whether it is a ceramic or crystal cartridge.
Cheers,
Geary
  • 0D3
Reply #6 on: August 24, 2013, 10:51:23 AM
OK, looks like we're on to something here.  My scope is only reporting 26-38mV.  That would be on the order of how much the volume is below what I think it should be.
This model has a cartridge with a stylus on each side.  You can flip it around by way of a handle that protrudes through the front of the tonearm.  One side is for 33/45 and the other side is for 78.
I guess it is time to go to the needle finder.
Thanks for the info, Geary.
Randall Massey
Offline galyons
  • Geary Lyons
Reply #7 on: August 24, 2013, 11:06:47 AM
Remember that is still a "healthy" output, (but in a totally unreferenced way!), it really depends on the gain of the amplifier.  Does the stylus(li) look OK?
Cheers,
Geary
« Last Edit: August 24, 2013, 11:08:23 AM by galyons »
Reply #8 on: August 24, 2013, 11:19:32 AM
Can you post a picture of the schematic, and check the tube pin voltages? Armed with those bits of information, the Forum denizens can identify anything grossly wrong with the electronics part.
Those flip-over cartridges were ceramic all right; that means no EQ and less gain needed, making the circuit simple. The wikipedia article "Phonograph" has a section on these cartridges. Since it's old, the needle is probably worn - replacements are available and should be inexpensive.
Offline Natural Sound
Reply #9 on: August 24, 2013, 11:38:04 AM
One other thing to note. Selenium diodes had a bit of internal resistance inherent to the design. Simply substituting with a modern silicon diode may rectify properly but pass too much voltage. A series resistor may be required.
More here...
http://w3hwj.com/index_files/RBSelenium2.pdf
  • 0D3
Reply #10 on: August 24, 2013, 01:29:52 PM
Here are the voltages on the 25C5 tube pins:
1.  0.5 VDC
2.  Not used
3.  28.5 AC
4.  -0.2 VDC
5.  -0.2 VDC
6.  21.8 VDC
7.  23.0 VDC
Randall Massey
Reply #11 on: August 24, 2013, 02:39:17 PM
I am obliged to point out that this thing is not isolated from the power line and is thus dangerous to use and more dangerous to work on.
Excellent help with the (theoretical) problem of why it is not working, though!
You should have around 135 volts on pin 7. The much lower measured voltage indicates that the power supply is not working. Since the 220 and 5600 ohm resistor are the only components in the power supply you have not already replaced, you should probably check them, as well as the orientation fo the parts that have been installed (a backwards cap will not do good things, even before it explodes).
  • 0D3
Reply #12 on: August 24, 2013, 03:51:57 PM
Paul, I appreciate the safety warning.  I've been very careful with the probes when testing and always check that the power plug is unplugged (twice) before doing anything inside.
I checked the 220 ohm resister while I had it out of circuit during the rectifier replacement.  I will check the 5600 when I pick up the fight tomorrow.
I do appreciate everyone's help.  It will be fun to get this thing working again.
As always, I'm learning a lot thanks to the awesome Bottlehead forum.
Randall Massey
Reply #13 on: August 24, 2013, 04:54:04 PM
Looked up the data sheet:
http://www.shinjo.info/frank/sheets/093/5/50C5.pdf
I see spec operation is with 7.5v bias at 50mA, which would be a 150 ohm cathode resistor. This circuit has dropped the screen voltage quite a bit (with the 5600 ohm resistor). I speculate that this is in order to get away with a lower grid voltage, and hence a lower required cartridge voltage - very clever!
Reply #14 on: August 24, 2013, 06:41:40 PM
I will reinforce that warning for two reasons -
One, is it's not our product and we can assume no liability for any well intended but inaccurate safety info you might receive here.
Secondly, I worked on an ACDC chassis myself a few months ago. The cautions routinely given should be heeded, as these things are very tricky. On the radio I restored the design was such that the chassis is hot when the radio is switched OFF. Not only did I have to use care in working on it, I had to instruct the owner to never remove the plastic knobs and touch control shafts. So make sure you thoroughly understand the setup, either by getting the service manual or by doing some careful measurements of the chassis potential with the unit both on and off.
