Are there any upgrade worthy parts on the SEX kit?
jon_k · 7337
Offline jon_k
on: October 17, 2013, 06:50:42 PM
Hi,
I'm new here. I got the kit with all the addons, it's on it's way (from massdrop). So, I've seen people on these forums replace capacitors, the volume knob, and various other components in these amps.
I was once told by another hardware hacker, if your manufacturer didn't have the inclination to select quality hardware, how can you believe they had worthy audio circuit design even worth upgrading?
Are there any parts on the SEX amp that would lead to the biggest change in quality to cost?
I got the SEX amp because close friends have assured me he honestly feels it is $2000 quality for $500 cost. I decided to experiment, and see if these claims are substantiated and am always willing to upgrade.
Any ideas?
Alps pot is a definite first order.
I plan on using my own power and signal wire as well.
« Last Edit: October 17, 2013, 07:06:20 PM by jon_k »
Reply #1 on: October 17, 2013, 06:59:12 PM
This comes up sometimes.  We provide exceptionally high quality parts where such parts are hard to replace or replicate (mostly transformers).  Where one could spend a few dollars or a few hundred dollars for the same value of cap, we will leave that up to each individual customer.  Often times even something like an Alps Blue just isn't available in the quantities we need with sufficient regularity to include it in our kits.
As far as what to replace, I would recommend replacing nothing, as this will often complicate troubleshooting if you have an issue, and you'll never know what improvement was gained by making the substitutions.
Offline jon_k
Reply #2 on: October 17, 2013, 07:11:22 PM
Fair enough!
I will only add the Alps pot after testing the stock unit, and may get time to experiment later.
I am probably also going to install two phone jacks with a resistor on source for attenuated listening. Those aren't really significant mods though.
I'm sort of in line with a $500 capacitor is probably not going to change the world audibly. Though you know some people think they feel it.
I've heard the SEX isn't anything to underestimate, so I'm really excited to see what it's all about.
I'll probably be back to post pictures of how I finish mine.
« Last Edit: October 17, 2013, 07:16:13 PM by jon_k »
Reply #3 on: October 17, 2013, 08:11:39 PM
Hi Jon,
I've spent the day reading this site looking for the same answers (i'm in the massdrop too),  and also couldn't help myself and added the C4S and Switch kit  ::)
My pre build parts list are a volume pot and headphone sockets, i.e. a better socket and adding an XLR socket too.  But i agree with the wisdom of building, testing, get used to it before making any more changes.  There are lots of interesting threads about "cap rolling" to make your head spin, but nothing really jumps out at me as being worth sourcing straight out of the box.
Also if you have a few hours to kill have a browse though the gallery section, some very nice builds in there.  I still cant decide on the cosmetic side of the build, i haven't done wood work since i was in school.
Mark
P.S. Fair warning to the moderators, there will be at least a dozen of us wide eyed eager tinkerers coming to disturb the peace!
Reply #4 on: October 18, 2013, 02:16:19 AM
Paul,
Very well said and good advice.
Jon,
I have been kit building for a long time, decades.  The Bottlehead circuits are simple, yet elegant.  There is noting there to get in the way of the music.
Here is my list, from most effective to least, of the tweaks most often used on Bottlehead equipment.  It is just my opinion, but it comes from experience:
C4S
Upgraded Iron
NOS tubes
Film output caps
Improved power supply, upgrade the final cap and a choke replacing the second resistor, maybe even both resistors
Upgraded volume control "device"
Improved, thick film, R1 resistors for the C4S
Fred Cree, ultra soft recovery, diodes replacing the UF4007 diodes
Improved signal path wire
Improved RCA Jacks
Improved headphone Jack/Speaker terminals
« Last Edit: October 18, 2013, 05:25:31 AM by Grainger49 »
Reply #5 on: October 18, 2013, 03:47:02 AM
Quote
Fred, ultra soft recovery, diodes replacing the UF4007 diodes
Hi Grainger,
Can you help identify the values of those resistors, wattage and working voltages?
I assume for the diodes the UF4007 replaces regular IN4007?
Thank you,
Mark
Reply #6 on: October 18, 2013, 05:00:23 AM
The UF4007s have pretty clean reverse recovery and seem to avoid RF hash. If I was going to improve upon them them I would install CREE high voltage schottky rectifiers, as FREDS sometimes add HF noise.
Reply #7 on: October 18, 2013, 05:24:59 AM
Mark,
I never built the SEX or SEX C4S.  So I can't supply the values.
Dan,
I'll change the recommendation.  I thought Freds and Crees were the same, just different names.
Reply #8 on: October 18, 2013, 09:14:42 AM
Cree is a manufacturer. It is almost impossible to get more than a 100v rating in silicon when making a Schottky diode, so they make high voltage ones from silicon carbide, up to 1200 volts. (It is possible in theory to make even higher voltage diodes from diamond crystals, but it's challenging!)
Schottky diodes have no reverse recovery at all; they are like tube rectifiers in that respect. The FREDs, fast recovery, ultra-fast recovery etc. designs reduce the magnitude of the reverse recovery spike, but cannot eliminate it.
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
Reply #9 on: October 18, 2013, 12:06:42 PM
As a recent builder of a S.E.X. kit I can highly recommend leaving it stock to begin with just so you can be shocked at how good it sounds even without any upgrades!
Offline compassionator
Reply #10 on: October 23, 2013, 09:35:18 AM
Hello, will adding a stereo mini jack output (rather than use an adapter) affect the performance of the amp?  If not, can it be wired from the standard jack?  Thanks.
Reply #11 on: October 23, 2013, 12:13:58 PM
Do you mean a 3.5mm socket instead of the stock 1/4"?  I don't see any reason why not.  Though as far as i know the supplied socket disconnects the speakers outputs when a headphone is inserted, so you will probably lose that functionality.
Reply #12 on: October 24, 2013, 10:19:15 AM
Sorry, about my wording...
Yes, 3.5mm and the stock 1/4".  Is there a way to wire both and not lose the disconnect the speaker outputs feature?  Or is this the function of the 1/4" jack?  If I wire the 3.5mm jack from the 1/4" why wouldn't it work?
Reply #13 on: October 24, 2013, 01:08:03 PM
I belive the supplied 1/4" jack is similar to this Neutrik model (http://www.neutrik.us/en-us/plugs-jacks/m-series/nmj6hc-s) which is a switched version.  Basically there are a set of input and output pins, outputs being wired to the speaker posts so when a headphone jack is inserted the contacts are lifted from the output pins, hence disconnecting the speakers.   I think that is how it works, but i have yet to receive my kit and confirm that.
You may be able to source 3.5mm socket with the same functionality, or just add a manual switch, or dont wire them up at all which is what i will be doing as i dont have any speakers to connect to it.  ...yet.
Diagram of switch contacts -> http://www.neutrik.us/zoolu-website/media/download/2804/Jack+Circuits
« Last Edit: October 24, 2013, 01:15:13 PM by mcandmar »
Reply #14 on: October 24, 2013, 04:48:18 PM
The actual sticking in, of the 1/4" plug, is what switches the speakers off.
Just like my wife, ba, dum, dumt. Sorry, channeling Rodney Dangerfield for a sec. ;D
You could wire a 3.5, in parallel with the 1/4. When you want to listen to the 3.5, just plug in a empty 1/4 jack in to turn off the speakers. Just make sure your 3.5 isn't  switching as well...John
« Last Edit: October 24, 2013, 05:01:41 PM by 2wo »
