The Fix Kit is live on the shopping cart
Doc B. · 14744
on: November 13, 2013, 12:54:24 PM
Offline porcupunctis
  • 0D3
Reply #1 on: November 13, 2013, 02:04:12 PM
Just ordered one.  Doc, you should add an option when you check out for the wood base.  I will try to call for one tomorrow.
Randall Massey
Teacher of Mathematics
Reply #2 on: November 13, 2013, 02:05:37 PM
Thanks, will do.
Offline bainjs
Reply #3 on: November 13, 2013, 02:23:47 PM
I also ordered one.  Can you provide a shot of the underside?  I plan to change the layout a little to make it front facing with the inputs/outputs on the rear and narrow the top plate.
Joel
Joel Bain
Reply #4 on: November 13, 2013, 06:35:05 PM
There will be some minor changes in the layout from the current build, so I don't expect layout shots to be up until next week.
(I can also say that there will likely be one surprise reason not to adjust the layout)
Offline debk
Reply #5 on: November 13, 2013, 11:35:50 PM
I ordered one also.  Don't know how much better it can make my Orcas sound, they sound great already, but I have a couple of full range driver speakers I have built that could definitely benefit from this.  It will be fun to play with!
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #6 on: November 14, 2013, 04:25:02 AM
Bought one!
Offline Alonzo
Reply #7 on: November 14, 2013, 04:55:54 AM
Bought one for my Frugal horns.
Paul,
 I also have a pair of SeXy Speakers, will the settings overlap the BSC previously put out for the SeXy speakers so I can remove my inline one?
Alonzo
Offline ffivaz
Reply #8 on: November 14, 2013, 08:58:37 AM
Bought! Looking forward to see how it fits my new fostex fe126en in a bk12m enclosure.
Fabien Fivaz
Reply #9 on: November 18, 2013, 11:55:08 AM
Couldn't resist this one.
I'm bettting that the surprise will have something to do with building this and the quickie into a single box as that is most likely what I'll do. ;-)
Offline Tanglewood
Reply #10 on: December 20, 2013, 08:12:30 AM
Just ordered one.  Seems like the perfect solution to replace the current baffle step network that I have on my speakers, which decrease the sensitivity and liveliness of the sound. I have the Fostex "boutique" 206ES-R's and I have them in the vented box, as my woodworking skills can't handle the horn. They actually sound pretty good in the vented enclosure, with just a bit of shout to be tamed. The Fix's 4 db cut is actually great as my FP2 puts out enough voltage for the Paramours that they can't be turned down quite low enough (even with the greater -db resistors in the stepped vol control). I'll be interested to compare this line-level solution with the current in-speaker network solution.
