Hum problem with new built Stereomour [solved]
Kmmm · 13015
Offline Kmmm
on: November 17, 2013, 11:47:20 AM
Hi
I have been using my new Stereomour for some days now. It does sound good but I have had trouble getting the hum down.
I have 108db speakers and they are not found of hum.
The amp is rigged for 45 tubes because these are supposed to be a bit more quiet then the 2a3.
I can't seem to get them as quiet as they are supposed to. The tubes in question are a matched pair NOS ST45 Aristocrat (1900Gm)
They read 5,42mV on left and 3,65mV on right channel.
The stock Sovtek 2a3 are only 2,42mV and 2,74mV in the same set up.
If the 2a3 measurements looks OK, then I guess the 45's are no good?
Is there anything else I should check before paying some one large amounts of cash for a new pair?
Please give your opinions on this one ???
Kaare
« Last Edit: November 20, 2013, 06:51:59 PM by Kmmm »
Kaare Mongstad
Reply #1 on: November 17, 2013, 12:22:04 PM
The Paramounts are a way, way, way better match to speakers that efficient.  AC heated directly heated triodes will only get so quiet, and ~3mV is a reasonable number to reach.
Offline Kmmm
Reply #2 on: November 17, 2013, 12:50:27 PM
Tank you for your reply.
I do belive that an upgrade to paramounts will sett me back even more then a set of new tubes.
I also do believe that after only one week it is a bit early to upgrade. I do think I have red about people getting down to 1mV and that I think would be ok even for these speakers.
Any thoughts about that?
Kaare
Kaare Mongstad
Offline Mike B
Reply #3 on: November 17, 2013, 01:17:42 PM
Why not try rewiring for 2A3?
It might work better, and 2A3's are in production.
Then you can get less hum and save up for Paramounts.
Reply #4 on: November 17, 2013, 03:03:30 PM
I agree that you should see less that 3mV, and the fact that you do get that low with 2A3s does suggest your 45s make a bit more hum than usual.
Just to be certain - "hum" is not a precise term in ordinary usage. To me it means low pitched 60 or 120Hz fundamentals with little or no harmonic content, as distinct from "buzz" which has substantial harmonic content. Buzz has different causes from hum, so I bring this up to be sure we are taking of the same thing.
Filament hum does vary a little between individual tubes. And the 45 was (I believe) designed to get some portion of hum cancellation by clever manipulation of the filament's magnetic field - though I've never found any details about this. From the simple theory, there is no reason the 45 should be different from the 2A3 since both are 2.5v filaments. For that reason, just trying more tubes improves your odds of finding a somewhat quieter one, but it's no guarantee!
Assuming it is hum (in my meaning above) it is always possible there there are other causes than just the filament power. A common one is imperfect filament power wiring, either unevenly twisted or routed too close to other sensitive components. If you post a picture of that portion of the wiring, we can probably determine if there is any potential for improvement.
Failing that, a DC supply for the filaments is the most likely solution. A simple form of that might be possible with the existing power transformer. It's not the best sounding approach, but if you are interested in it send me a PM.
Offline Kmmm
Reply #5 on: November 17, 2013, 08:01:44 PM
Thank you for your up lifting and informative reply :)
I think the best thing will be to start with a picture of the wiring.
I will also contact Brent Jessee from audiotubes.com to see if he can come up with some quiet 45's
Then the last option is to make a DC supply.
I'll post some pictures later tonight.
cheers
Kaare
Kaare Mongstad
Offline Kmmm
Reply #6 on: November 18, 2013, 03:46:57 AM
Just got an e-mail from Brent Jessee where he tells me that he has not heard that the 45 tubes are any quieter or have less hum than the 2A3.  Both tubes, especially the very old ones, are susceptible to noise and hum due to out gassing of the internal components. This may go away with time once the tubes are put into service, and a long burn in period may reduce the hum as the getter absorbs the gas. It may take 200-300 operating hours.  He have had hum issues with both types.
Cheers
Kaare
Kaare Mongstad
Offline Kmmm
Reply #7 on: November 18, 2013, 08:09:31 AM
Here are some pictures of the amp.
There are probably some cables worth moving around?
I have been using the 2a3 tubes for a while and if I get the hum down below 2mV I think I'll be happy.
The Stereomour is only driving the the full range horn(AER MD3). That's also the reason for going with the 45. I really don't need much power.
The bass is 15" BD-design and is driven by two 30w LM3875 (AudioSector).
Kaare
Kaare Mongstad
Reply #8 on: November 18, 2013, 08:32:19 AM
Have you verified that the hum is only from the output tubes, i.e., have you tried a diferent 12AT7?
Reply #9 on: November 18, 2013, 09:14:02 AM
Along the lines of Dan's post above, have you tried shorting plugs to verify that the problem is from the Stereomour forward?
There is a sticky in Technical Topics about Shorting Plugs.
I do believe that the 108dBW speakers are the culprit, but we must ask these questions first.
Offline Kmmm
Reply #10 on: November 18, 2013, 09:44:29 AM
Hi Doc B.
I have verified that it's not the 12AT7.
I have also tried a NOS Siemens E81cc. It gives more or less the same result.
The 45s perform slightly better with this tube. The 2a3 a bit worse. But it is only very little.
Kaare
Kaare Mongstad
Offline Kmmm
Reply #11 on: November 18, 2013, 10:00:29 AM
Hi Grainger49
Yes I have a set of shorting plugs and use them. I have learnt that 108db speakers might be a bit on the sensitive side for the Stereomour.
But I would like to get the hum balance down to below 2mV as mentioned in the manual. 1mV would be even better.
I could listen to the 2a3's with 2,5mV but it would be nice to get the hum a little lower.
Not being able to get the 45's below 3,5mV at best, is a bit annoying.
So
Kaare Mongstad
Offline fullheadofnothing
Reply #12 on: November 18, 2013, 10:12:38 AM
Looking at your build, it kind of looks like there isn't a lot of clearance between your output transformers and the chassis plate. Are the fiber shoulder washers installed?
Reply #13 on: November 18, 2013, 10:18:52 AM
Have you tried moving the amp to a different location and remeasuring the hum level? Sometimes the magnetic field that is creating the hum is from other gear near the amp or at least some of it. This is what makes it so tricky to troubleshoot, there can be more than one cause.
Offline Kmmm
Reply #14 on: November 18, 2013, 10:28:51 AM
Hi Fullheadofnothing.
You are absolutely right. The OT-2's are touching the chassis on the underside. There where 4 fiber shoulder washers missing.
I could try to find a substitute.
Kaare Mongstad
