Mcandmars ramblings \ build thread...
mcandmar · 82005
Reply #45 on: March 09, 2014, 04:37:37 PM
Stepped Attenuator:
I recently got my hands on a vintage Goldpoint ladder attenuator and matching balance control from eBay. The switches are dated Sept 1996 and have never been used.  They are 75k items however since i have no need for a balance control i am going to rebuild it into a 100k attenuator for use in the S.E.X. amp.
Since the ladder version of the Goldpoint has been out of production for so long i did a bit of digging around in the internet archives and found a copy of the website from early 2000 with the assembly instructions.  I have attached the list of resistor values from the Goldpoint site along side the values used in the Chinese attenuator i am currently using.  I do prefer the look of the curves on the Goldpoint item, smoother looking and starts to raise the volume sooner than the Chinese version.  Also the switch feel is much more pleasant on the Goldpoint.  As soon as the resistors arrive from Mouser i will assemble and add some more pics.
If anybody knows what resistors were originally used in these i would love to know, they all have six colour codes which i had never seen before, which translates to 1% 50ppm.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fbottlehead.com%2Fsmf%2Findex.php%3Faction%3Ddlattach%3Btopic%3D2963.0%3Battach%3D5188%3Bimage&hash=04b9f5bab4ba25ff1d3d475eb448c5f5f6445aaf)
Reply #46 on: March 09, 2014, 08:21:31 PM
The 75K control will work quite well in the SEX amp, there's no need to rebuild them.
Reply #47 on: March 10, 2014, 12:04:54 AM
I feel the need to warn you:
I am not aware of the Goldpoint balance control.  But I have worked with balance controls that are continuous.
A balance control attenuates the left channel and leaves the right channel alone when you fade to the right channel.  It does the opposite when fading to the left channel.  The operation of leaving one channel alone is unusual for a dual channel device.
If Goldpoint made a switch specifically for balance it will have no positions for the two channels either side of centered.
If Goldpoint used a standard switch and just shorts all the positions either side of center you will be able to make a stereo attenuator from it.
« Last Edit: March 31, 2014, 03:05:10 AM by Grainger49 »
Reply #48 on: March 10, 2014, 09:45:23 AM
Thanks Paul, that is what i was querying the other day.   The 75k attenuator i will leave as is, its only the balance control i am going to rebuild back into a volume attenuator.  The dilemma i have is which will be better, the rebuilt one using modern Vishay Dale RM/CMF55's, or the original one which i think has "1%, 1/2 watt, Xicon, 50ppm, metal film" resistors.
Thanks for the heads up Grainger, that is exactly what it is, the same physical switch unit with half the resistor positions joined together.
Reply #49 on: March 22, 2014, 04:41:06 PM
So you know that feeling when you hunt down a pair of nice tubes for a bargain price. That was me on Friday evening with a beer in hand unpacking a NOS pair of Sylvania Black Plates, my favorite.
These tubes turned out to be a rather unique variety i have never seen before, they have the Sylvania skinny black plate primary, but with the regular GE/RCA grey plate secondary inside a coin base package.  Also the labeling on the tubes is green which i have never seen before, they are always yellow. I was really curious to hear what these oddballs sounded like.
They initially powered up fine, plugged the headphones in and had a static noise on the left channel.  Hmm, tap tap, bbbzzzzzZZZZtt POP fzzzztt, and with that the heater went out and the other tube dimmed and the pilot light started flickering. I somehow managed to flick the power switch off and rip the headphones off my head without spilling the beer all over the place. Deaf in one ear and with a heart rate through the roof no less.
After i regained my composure and burnt my fingers on the tube (i do that every time), i swapped them around and powered up again without the headphones.  One dead tube, and obviously still shorting out the heater supply. On closer inspection i found the issue is one of the grid support rods is making contact with the heater element, incredibly frustrating i cant get in there to do anything about it.  I may have to introduce this tube to Mr Hammer and Dr Dissection in the name of science.
Thankfully the fault seem to be on the secondary side so it didn't introduce the DAC to a heater supply, and the headphones survived the ordeal too.  Only permanent damage is to my hearing and nerves.  I have a new rule: Always use sacrificial headphones when tube rolling, and be ready for a surprise!
Reply #50 on: March 26, 2014, 07:32:12 AM
I think your new rule is prudent. My scare, documented in another thread, caused by transistor failure in the C4S board will require me to follow your rule and use a pair of cheap speakers for a few hours after I reinstall the board.
Reply #51 on: April 04, 2014, 04:00:26 PM
What better way to spend a friday night than waving a soldering iron about, sad b£&*$@% that i am.  I finished rebuilding the vintage Goldpoint attenuator a while back and never got around to fitting it so i had a look through my parts stash at the bits and pieces i have gathered up and figured i would throw them all in at once.
While i was switching out the attenuator i took the opportunity to replace the last of the audio path wiring from the RCA inputs to attenuator, and the short length from there to the standoffs with dual core silver plated shielded wire sourced from Navships on eBay. I've always liked his stuff, nice quality and really cheap.
Other misc bits thrown in include two new RCA input jacks, two .1% 25ppm Dale 1/2w resistors for the power supply, two Panasonic 22uf caps to replace the Lelons, and as an experiment i added two .22uf Mundorf bypass caps across them to see what happens.  I did a similar experiment with my "Babybottle" quickie and was really surprised at the effect they had.
Conclusion?  The Goldpoint is just lovely, instead of the clunk clunk clunk of the eBay attenuator it goes tick-a-tick-a-tick-a-tick, its just sexy.  The amp also sounds different, seems much clearer with better detail in high frequencys.  Then again after four cans of Heineken a speaker in a metal dust bin would sound good to me ;D
« Last Edit: April 29, 2014, 08:46:51 AM by mcandmar »
Reply #52 on: July 02, 2014, 10:17:33 AM
(Tung-Sol 6DN7's)
I managed to score a pack of five NOS Tung-Sol tubes which i have been looking for since i bought this amp, they are by far the rarest of all the 6DN7 tubes.  I blame Doc for this due to his comment about them sounding a bit different on the forum :P
The construction and plates are a little bit different to regular GE/RCA tubes, the first sections have black plates, the second sections have grey plates, and they have a D shape getter mounted on the side of the first section which is unique.  Every other tube i have seen has had an O ring getter behind the second section.
First thing i did was plug into into my tester and measure the output, results were a bit all over the place, for five NOS tubes from the same batch i was expecting a bit more consistency.  I also noticed they all measure close to the rated 40ma for the second section as per the datasheet, where as most of my Sylvanias measure higher in the 50ma range which is interesting, and has me wondering if this contributes towards my preference for them having a slightly stronger output.
So how do they sound?  They have less of the midrange tubyness the Sylvanias have, or if you like they are a little less euphoric.  Low end is similar, possibly more extended, but cleaner and better defined. The high end is also clearer and more extended then the Sylvanias. Overall i think they are a more balanced sounding tube vs the Sylvanias that seem to emphasize the midrange more.  There is some other quality to the Tung-Sol's i haven't been able to pin point yet, they just sound a bit different, but in a good way.
As with all the 6DN7 varietys were not talking a night & day difference, its more subtle to the extent it takes a pair of headphones and some careful listening to pin down the differences.  Having said that i would confidently take the Pepsi challenge on GE/RCA vs a pair of Sylvanias or Tung-Sols, the difference is enough to be able to single them out, and enough to make them worth seeking out.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fbottlehead.com%2Fsmf%2Findex.php%3Faction%3Ddlattach%3Btopic%3D5316.0%3Battach%3D6411%3Bimage&hash=0fbe67dcdb9786a6774fc90baf134201108f703c)
Offline johnsonad
Reply #53 on: July 02, 2014, 12:54:07 PM
I agree with you, the Tung Sol's sound good but very similar to everything else out there.  My pair was a gift from a fellow Bottlehead and I leave them in not out of their sound but to honor the gift.  The 6DN7 lasts forever in this amp!
Offline ALL212
Reply #54 on: August 21, 2014, 03:39:16 AM
I've started my build and am following recommendations here - nice build by the way!
Is there a range that is acceptable to the 100r Resistors to be put in the heater circuit?  I've got quite the pile of resistors but none (other than some monster 12w Mills that are not going to fit) that are 100r.  Recommeded wattage range?
Aaron Luebke
Reply #55 on: August 21, 2014, 04:40:23 AM
Good question, and i don't really know the answer as that as the value was recommended by PJ.
From what i understand using lower value resistors will center the voltages more accurately, but at the expense of using more current and dissipating more heat.  I dont know how to calculate the current across the resistors, and therefore the wattage rating needed so hopefully one of the BH guys will chime in and educate us...
Reply #56 on: August 21, 2014, 05:18:40 AM
Ohms law works pretty well.
6.3V with 200 Ohms across it.
P=(V^2)/R
To keep temperature reasonable, triple that power to get your resistor wattage rating.
« Last Edit: August 21, 2014, 06:03:26 AM by Caucasian Blackplate »
Reply #57 on: August 21, 2014, 06:00:20 AM
See, you always make it sound so simple :)
In that case i get a little under .2w with 100r's so a quarter watt resistor isn't going to cut it, unless you jump upto 200r's in which case your down to ~.1watt. Got it.
Thanks Paul!
Reply #58 on: August 21, 2014, 06:04:25 AM
.2W of dissipation means 1/2 Watt minimum resistor size, but more likely a 1W part.
Offline ALL212
Reply #59 on: August 21, 2014, 09:59:05 AM
Thanks gents!  'preciate the info.  I can sling solder around with the best of 'em but my electronic knowledge is on the level of what a dog knows about brain surgery.
Aaron Luebke
