Corcom EMI/RFI filters
butchbass · 8316
Offline butchbass
on: January 04, 2014, 02:11:48 PM
Does anyone in the BH community use Corcom filters for power conditioning? It seems like they would do an excellent job and at a fraction of the cost of some of the big name power conditioners?
Butch Gross
Stereomour II/  Blumenstein Orcas, Dungenes/Schiit Bifrost Multibit/Amarra
Reply #1 on: January 04, 2014, 02:39:43 PM
I have used Corcom in the past but haven't used them with Bottlehead equipment.
« Last Edit: April 08, 2014, 02:45:03 PM by Grainger49 »
Reply #2 on: January 04, 2014, 03:23:55 PM
I'm looking into it for a future project. There is a great variety of models, and it's quite a pain to figure out what the differences are - I've downloaded far too many data sheets! Based on various notes from the late John "Buddha" Camille, who really knew a great deal about these things, you want decent attenuation down to basically as low a frequency as you can afford ...  :^) ... I figure I'll know more in six months or so, once I digested some of the information I've been gathering.
Offline Wardsweb
Reply #3 on: January 04, 2014, 03:43:16 PM
I have used Corcom PS0SSSSXB in Bottlehead and my own DIY designs for over 10 years with very good results. Here is a picture from around 2002 of my custom version of a Foreplay II.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.wardsweb.org%2Faudio%2Fforeplay%2Fimages%2Fc3b.jpg&hash=0c00f95ea8b1434cfc048f3b54d5edad77516626)
Reply #4 on: January 04, 2014, 06:10:34 PM
I haven't used Corcom specifically but have used other brands in various projects. From what i have seen the sizing of the choke is what really matters, the caps from live to neutral really only stop clicks and pops. i.e. if you hear noises turning lights on/off etc.  I've also never really liked the concept of the caps between each phase and neutral as they inject voltage/current into the earth circuit.  Interestingly "hospital grade" versions of these filters don't have those Y caps.
Its also worth reading the "Felix Filter" thread on Audio Circle, i built a similar filter using parts i salvaged from old computer ATX power supplies, it was a lot more effective than the prebuilt units at cleaning up noise from switching power supply's. In my case i have a bunch of cell phone chargers and various other wall bricks in the same room that all contribute to the noise, some to a hilarious degree. There is also the argument that all this noise is so far above what we can hear that's its irrelevant.
I look forward to your findings Paul, no better person to get to the bottom of all this..
Offline krikor
Reply #5 on: April 08, 2014, 09:05:42 AM
Interested as well. I recently sold off my PS Audio Powerplant as part of downsizing effort, but would like to try some sort of passive filter. Looking at perhaps building the Felix. Curious what others use at the lower end of the price spectrum.
Reply #6 on: April 08, 2014, 10:28:03 AM
Forgot about this, so how is the digestion coming along Paul :)
I'm still experimenting with this myself, i only recently picked up a second hand Belkin PureAV.  Its just a basic passive filter inside with a some common mode chokes, but with four separate channels so in theory its providing some isolation between devices.  The reason i bought the unit was to have something sitting in front of my Bottlehead amps.  I do plan to modify it (surprise surprise), and move my two felix filters into the same enclosure.
The voltage monitor is interesting, even back in the days of using opamp based headphone amps i always knew they sounded best from ~1am to 6am in the morning, now i can clearly see thats the only time of the day where i get 240v, from 6am to midnight my mains is down ~230v.
The PS audio powerplant is a very interesting device, from what i understand its basically a big amplifier than creates an AC signal to sit on top of the mains to correct the peaks, basically giving you a true sinusoidal sine wave again instead of the flat tops which is so common theses days due to switching supplies.  I assume it voltage regulates too?  Why any of that makes a difference to a device that converts AC to DC i don't know, but i like the theory :)
« Last Edit: April 08, 2014, 10:31:35 AM by mcandmar »
Reply #7 on: April 08, 2014, 02:58:59 PM
I was doing this study for the long-delayed SR45. On balance, I chose the Corcom EC series, specifically the 3-amp version. The higher current ratings have less rejection  below 1MHz so if I needed more than 3 amps I might go through the catalogs again.
The late John "Buddha" Camille provided an extensive discussion in an old VALVE issue, under the title "Buddhafied Afterglow". Following those ideas, I am implementing a post-filter to get the attenuation down to a few kHz. Still no direct experience - I should probably put the whole assembly in a box for A-B comparisons.
So, no proven results but that's where it stands right now.
Reply #8 on: April 08, 2014, 03:22:52 PM
Thanks Paul, i have a bunch of Valve issues achieved that were on the old website so i'll see can i find that article.
In case its of interest to you this is the choke used in the Felix filter http://www.coilcraft.com/pdfs/comoco.pdf , obviously you have to add the capacitors around it to complete the CLC circuit.
Offline johnsonad
Reply #9 on: April 09, 2014, 12:59:04 AM
One of my favorites is a Hammond 193L choke. Put it in a box and connect it across the hot and neutral. It makes a surprising amount of difference. I use this after a PS Audio Power Plant for my pre and power amps.
Offline RPMac
Reply #10 on: April 10, 2014, 03:10:37 AM
Buddafied Afterglow is in Volume 6, Numbers 3 & 4
I've been intending to use those components in front of a 5kVA transformer wire for balanced output.
I have a 1.5kVA transformer with balanced output in use in front of my BottleHead gear, but without any filtering. I have the advantage of being at the end of my power line with a step-down transformer for my house only. Even with my older amps and 95dB speakers, noise hasn't been a problem therefore my procrastination.
I'll be interested to see what changes, if any, that PJ makes.
Grainger, thanks for pointing out my mistake on the transformer ratings. One other point, for balanced power, the transformer rating should be at least twice what would be required for the load it will be supplying. You are using the transformers at half the designed voltage, so to be safe the max current rating of the transformer should be 4x the actual current draw. I hope this is clear.
« Last Edit: April 11, 2014, 04:39:33 AM by RPMac »
Reply #11 on: April 10, 2014, 03:45:00 AM
I've found some info about that searching the internet but no schematics or pics of installations. I'm a little confused, why doesn't it appear as a short when placed across the neutral and live?
Offline krikor
Reply #12 on: April 10, 2014, 04:16:25 AM
Well those are two routes I've been looking at myself... Belkin PF60 or building a few of the Felix filters. I was thinking of just going cheap a simple with a couple of the Tripplite Isobars, but something about those things doesn't sit well with me. Perhaps they are just not audiophile approved enough for me :)  Oh, and yes, the PS Audio Powerplants do voltage regulation, it's one of their key features.
The PF60 has six separate filters, one for each of the six duplex outlets, and one is a high-current filter so it would meet all my needs. Also has trigger/delay capabilities which is a plus and you can get them for $200 through Belkin. Seems like a lot of features packed in for that price, which makes me wonder where are they skimping.
I had forgotten all about the Hammond Choke Tweak. Thought about doing it years ago but never got around to actually ordering one. Didn't think it was necessary with my PS Audio Powerplant Premiere in the mix. After years of reliable use the powerplant went bad on me so I got it repaired and then sold it off since I could cover the repair and still pocket enough to play around with some other options. I may end up regretting it, but that's all part of the journey.
I'm thinking of several different options right now.
  • Off-the-shelf EMI/RFI filter boxes (like those from Corcom or others) wired to separate outlets in a DIY power strip/distribution box
  • Felix filters instead of he off-the-shelf boxes (think it will probably give me better filtering at lower frequencies)
  • Hammond 193 Choke Tweak - probably do this regardless as it is not exclusive of those other approaches
  • Belkin PF60 - well that's the easiest with the most ready-to-go features and flexibility, but where's the fun in that?
« Last Edit: April 10, 2014, 04:23:04 AM by krikor »
Reply #13 on: April 10, 2014, 04:23:13 AM
For the same reasons that the coil of wire that makes up the primary of a power transformer also doesn't appear as a short to an AC line supply.  (The choke can be considered a power transformer with one winding, and an airgap)
Reply #14 on: April 10, 2014, 04:59:21 AM
The unit i got is the PF40 which is the four channel version, if you look at the internal pic i posted, the far right channel is the "digital" section with two chokes, the two channels in the middle are identical (audio&video) except for the left one is switched, and the far left channel is also switched and only has two caps and a ferrite bead, thats the "high current" output.
The two switched channels can be turned on/off with the power button on the front, or you can feed it an AC or DC signal in the back to trigger them. The delay function is a set time, once triggered it waits 3-4 seconds before turning on those two channels.
The far left board has a metric crap ton of MOV's to withstand a lightning bolt from the hand of god, and the rest of the board is a mystery to me.  All i can make out is the transformer runs a positive and negative 12v regular to feed a quad channel opamp, what its doing i have no idea. Apart from the simple remote trigger logic, the front panel displays voltage & current, and that's about it.  Its a nicely made unit but there is nothing clever or "expensive" inside the unit, i would say the bulk of the cost is the pretty enclosure.   The reason i liked it was up until now i was making separate units for different equipment, at least now i can have it all inside the one box, and with the PF40 there is plenty of room inside the case as it has two less channels than the PF60.  For example there would be plenty of room to mount a Hammond 193 in there connected to a few outlets.
That makes perfect sense now you say it.    Though that does starts to blur the lines for me on the differences between a choke and auto former, apart from the take off taps aren't they essentially the same thing being a single winding?     Reason i ask is i have a huge 1300watt autoformer here.
