Help, voltage problem!
smallmany · 8768
Offline smallmany
Reply #15 on: February 24, 2014, 08:15:40 PM
resistance of 600k ohm on terminal 13 , it is above the 270k but it varies with ohmmeters right?
Reply #16 on: February 25, 2014, 04:58:03 AM
The difference may be due to the fact that the tubes haven't burned in yet. Just enjoy some music for a while and see if the imbalance gets better as the tubes break in.
Reply #17 on: February 25, 2014, 07:08:25 AM
Yes indeed.
Offline smallmany
Reply #18 on: February 25, 2014, 08:49:12 AM
Since tubes degrade faster the hotter it gets, is it possible to add a heat sink to deviate the heat away?
Reply #19 on: February 25, 2014, 09:02:42 AM
There is a range where a given tube will operate well.  If you go too high, you will indeed shorten the life of the tube, if you go too low, you get poor performance out of the tube.  We are running the 6080 at about 25% of its maximum dissipation rating, so there is nothing to be concerned about here.
Offline smallmany
Reply #20 on: February 26, 2014, 03:38:01 PM
What areas of the crack controls the sound quality of the left audio? Im still not hearing any changes to the recessed/less prominant left side of the headphone. I know that it is not my source/headphone because without the amp it is perfectly balanced, and switching the rca connector reverses the sound quality so it must be the amp itself
Reply #21 on: February 26, 2014, 06:34:28 PM
So switching the cables that come into the amp moves the recessed quality to the other channel?
Offline smallmany
Reply #22 on: February 26, 2014, 07:14:33 PM
Yes   :-\ the lesser stellar sound stays on to same channel.
Reply #23 on: February 26, 2014, 07:42:04 PM
That would be a "no", the stellar sound does not switch channels.
How are your voltages?
If this doesn't clear up in 50-100 hours of operation, I would look at rewetting any solder joints that don't look shiny.
Offline xiawei
Reply #24 on: February 28, 2014, 06:37:47 AM
Have you solved the problem yet? I have similar problems.
Offline smallmany
Reply #25 on: February 28, 2014, 08:59:25 AM
Not yet, but i'll be taking PB's advice and rewet some joints. Will post an update if it improves performance.
Reply #26 on: February 28, 2014, 09:14:20 AM
If you can please post any  voltages that are out of spec we might be able to offer some more ideas about what to look for.
Offline smallmany
Reply #27 on: February 28, 2014, 11:06:56 AM
ironically, I blew my fuse doing a voltage test. Once I replace those, i'll get on it Doc.
Offline smallmany
Reply #28 on: February 28, 2014, 01:34:47 PM
will this fuse work
1A 250VAC
Type number:MFG
5.2mm x 20mm
interrupting current : 35 A 250VAC
miniature fuse
1   80
2   175
3   0
4   175
5   80
6   0
7   103
8   0
9   104
10   0
11   0
12   0
13   175
14   0
15   196
20   0
21   219
A1   80
A2   0
A4   0
A5   0
A6   80
A7   0
A9   0
B1   80
B2   175
B3   103
B4   80
B5   175
B6   103
B7   0
B8   0
« Last Edit: February 28, 2014, 04:28:27 PM by smallmany »
Offline smallmany
Reply #29 on: March 02, 2014, 04:01:50 PM
will it harm my headphone/amp in anyway, if i maximize the volume on the crack amp and control the volume via computer?
