My modern version of a Dynaco ST70
Wardsweb · 15473
Offline Wardsweb
on: March 25, 2010, 04:58:01 PM
This is what I came up with for building a modern version of a Dynaco ST-70. The only original parts used were the output transformers. Everything else is new. I upgraded parts and driver board. I drilled and punched a chassis for the new layout and had it chromed. I build a new cabinet out of Baltic birch and veneered it in cocobolo. I was inspired after the Quickie I built with a similar cabinet design.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwardsweb.org%2Faudio%2FST70%2Fbuild%2Fst70_31.jpg&hash=aacfb7c835b4a6b5d24ed1c1a18a16ed24140e62)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwardsweb.org%2Faudio%2FST70%2Fbuild%2Fst70_33.jpg&hash=0ddfeb3c4c60a56497d4af082b834e18c5f9bfd9)
Reply #1 on: March 25, 2010, 06:26:18 PM
Sweet!
Reply #2 on: March 25, 2010, 07:13:39 PM
Can you build me one?
That is really pretty, whose driver board did you decide on?
Reply #3 on: March 26, 2010, 12:12:36 AM
WOW !
That is incredible.  What are the two red topped things between the output tubes and the driver tubes?
Offline Wardsweb
Reply #4 on: March 26, 2010, 02:14:15 AM
I used Shannon Park's board. You can see in depth details on my website:
http://wardsweb.org/audio/ST70/
Offline corndog71
Reply #5 on: March 26, 2010, 03:39:40 AM
That is one sexy amp!
Rob
Offline ironbut
Reply #6 on: March 26, 2010, 07:44:03 AM
Beautiful work!
How hard was it to do the veneer?
steve koto
Offline Wardsweb
Reply #7 on: March 26, 2010, 09:23:36 AM
Beautiful work!
Not hard at all actually. The side you glue and then trim. The top is one piece. I glued it first and then cut out the center.
Offline Wardsweb
Reply #8 on: March 26, 2010, 11:07:02 AM
WOW !
They're several test points on the chassis used for setting bias. The original amp had the tube socket on the front. I opted for a some nicer tip jacks.
Reply #9 on: March 26, 2010, 11:25:18 AM
I take it that the right and left pair of output tubes are still biased together?  I got a schematic some time back that allowed bias for each tube and allowed using non matched tubes.
Reply #10 on: March 26, 2010, 06:13:34 PM
Let's see the inside!
Offline mrarroyo
Reply #11 on: March 27, 2010, 05:38:27 AM
That is sweet indeed! How many watts does it put out? I wonder if I could use it to power my AKG K1000, and if yes how much to build me one? ;)
Reply #12 on: March 27, 2010, 06:08:13 AM
The Stereo 70 is 35 WPC.  That was part of Dynaco's numbering scheme.  The parts are mostly being cloned by a number of companies.  Luther bought his "junker" ST-70 for the old, desirable, cloth insulated  wire output transformers.
If you use the link he supplied in reply #4, you will find a parts list.
And with a few more pictures of the inside goodies and this MANUAL downloaded you can build your own.
(That is a hot key.)
Reply #13 on: March 27, 2010, 09:22:01 AM
K1000's are very nicely driven by Paramounts, and the DC on the filaments keeps it super quiet. Oddly enough, 2A3's are plenty of power for the K1000. I will test the Stereomour also to see if it is suitable for K1000 duty, but I'm somewheat skeptical.
Offline mrarroyo
Reply #14 on: March 28, 2010, 03:04:18 AM
The Paramount using the 300 tube looks awesome! However, I would not be able to build it due to both poor soldering technique and poor eyesight. Since I would have to have it built I will have to wait until I can come up with $2,000. Thanks.
