resistance check help
bgf · 2946
Offline bgf
on: February 24, 2014, 12:05:58 PM
everything was going smoothly till i checked A1 to B4.  this is what i tested with 300B tube in place.
A1 5.4 ohm
A2 3.14 m ohm
A3 45.7 k ohm
A4 4.2 ohm
B1 4.2 ohm
B2 3.14 m ohm
B3 43.1 ohm
B4 5.4 ohm
volume knob was at the same setting, checked solder joints looked good, thought i would give you all a brain teaser before i started going over the wiring frame by frame.
brent fauss
Reply #1 on: February 24, 2014, 05:07:25 PM
Your resistance readings are correct, we made a minor adjustment to the 4 pin tube socket pinouts in the manual (my error actually), and the resistances didn't get rearranged.
Thanks for checking in, you're all set for voltage checks!
Offline Chris65
Reply #2 on: February 24, 2014, 05:18:32 PM
Paul, could you just clarify what the correct values are please.
Do A/B2 and A/B3 just need to be transposed?
I notice Brent has 43ohm on B3, guess that should be Kohm?
Reply #3 on: February 24, 2014, 05:36:35 PM
What you want is ~4 Ohms on either A/B1 or A/B4, then something slightly higher than that on the companion pin.
A2/B2 will be whacky, and shouldn't be zero.
A3/B3 will be 0-50K, depending on the volume control position.
Offline Chris65
Reply #4 on: February 24, 2014, 07:09:29 PM
Ok, thanks for clarifying that.
