Bottlehead Kits
BeePre
resistance check help
bgf
2947
bgf
Jr. Member
February 24, 2014, 12:05:58 PM
everything was going smoothly till i checked A1 to B4. this is what i tested with 300B tube in place.
A1 5.4 ohm
A2 3.14 m ohm
A3 45.7 k ohm
A4 4.2 ohm
B1 4.2 ohm
B2 3.14 m ohm
B3 43.1 ohm
B4 5.4 ohm
volume knob was at the same setting, checked solder joints looked good, thought i would give you all a brain teaser before i started going over the wiring frame by frame.
brent fauss
Paul Birkeland
Global Moderator
Hero Member
Re: resistance check help
Reply #1 on:
February 24, 2014, 05:07:25 PM
Your resistance readings are correct, we made a minor adjustment to the 4 pin tube socket pinouts in the manual (my error actually), and the resistances didn't get rearranged.
Thanks for checking in, you're all set for voltage checks!
Chris65
Sr. Member
Reply #2 on:
February 24, 2014, 05:18:32 PM
Paul, could you just clarify what the correct values are please.
Do A/B2 and A/B3 just need to be transposed?
I notice Brent has 43ohm on B3, guess that should be Kohm?
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
February 24, 2014, 05:36:35 PM
What you want is ~4 Ohms on either A/B1 or A/B4, then something slightly higher than that on the companion pin.
A2/B2 will be whacky, and shouldn't be zero.
A3/B3 will be 0-50K, depending on the volume control position.
Chris65
Sr. Member
Reply #4 on:
February 24, 2014, 07:09:29 PM
Ok, thanks for clarifying that.
Bottlehead Kits
BeePre
