4-channel Quickie
marty51 · 6776
Offline marty51
on: March 08, 2014, 06:49:18 PM
I intend a 4-channel Quickie for the mid & high of a triamp system.  I will make a new top plate from 2 Quickies with a single input and output for each channel (all I need).  Can I run 4 tubes from the battery packs for 1 Quickie?  Looking at the current draws, it appears possible (with obvious reduced battery life).  2 separate Quickies is an amp too far for the shelf.
Many thanks
Marty
Reply #1 on: March 09, 2014, 12:39:08 PM
You need a separate D-cell for each tube's filament.
You could use the smaller C cells, to more closely match the reduced 9-v battery lifetime when they are feeding four channels.
Offline marty51
Reply #2 on: March 11, 2014, 05:21:44 PM
Thanks for your quick reply, Paul.  I was gifted a decent lab bench DC power supply recently so I assume I can use that for the B+?  Overkill, I know but a freebie.  In which case does the PJCCS do anything for me?
Really looking forward to trying this revered preamp.
Marty
Reply #3 on: March 12, 2014, 12:11:25 AM
Marty,
Some of the magic of the Quickie is that it is battery powered.  There is no AC ever connected to it, it can't hum from the power supply.  Even a lab supply could introduce some hum.  And maybe not.
« Last Edit: March 31, 2014, 03:02:20 AM by Grainger49 »
Reply #4 on: March 12, 2014, 10:35:31 AM
The bench supply is probably OK for the B+.
The PJCCS is still a worthwhile upgrade.
Offline marty51
Reply #5 on: March 16, 2014, 04:52:58 PM
Thanks, all, for the replies.  This forum is what makes BH amps THE choice for the novice.  Only one way to find out - 2 Quickies ordered.
Marty
Offline marty51
Reply #6 on: May 07, 2014, 10:50:03 PM
I've built one of my Quickies stock (with PJCCS) & put it the mid channel of a triamp system, sitting on some foam supports and connected with screened interconnects.  It works, at least it measures right and it plays music but with some issues.
The one that concerns me the most is D cell life.  I lost left channel at 20 hours, one D cell down to 1.05V (other is 1.35V).  New Duracells - Costco's best.  Anyone ideas why one channel would have a shorter life?
Haven't formed an sonic impression yet because it's still too new but, for the record:
I have mobile phone interference - will try PJ's RF capacitor suggestion.  The intention is to put the guts of 2 Quickies in a bespoke single metal case later.
Very low volume scratchy noise from that left channel (not tube related) with shorted inputs.  Have re-flowed all joints.  Can't hear it from 300mm away so can live with it.  EDIT: This was RF noise from a MacMini next to Quickie.  Alu foil shield as temporary fix.
Microphonics are simply horrendous.  Piano notes audibly distort at higher volume with all 3 flavours of tube I have.  I will try the various fixes here but this might be the deal breaker for this fun little amp in my system.
Still looking for a 4 channel preamp solution with about 6dB gain.  Any recommendations for modifiable versions of other BH's?
« Last Edit: May 08, 2014, 04:10:29 AM by marty51 »
Marty
Reply #7 on: May 08, 2014, 12:32:31 AM
The D-cells power the heaters.  The draw is predictable.  If you had bad life on one cell, it is most likely because it was weak to start with.
I don't remember if the D-cells are dedicated to a tube or used for both tubes.  Either way, it could be a very odd tube, drawing too much current.  But it was most likely a bad battery to start with.
Reply #8 on: May 08, 2014, 03:37:07 AM
I have had odd issues with that particular brand of batterys, i had one 9v suddenly drop to less than a volt, but it still created a circuit so the amp was working on reduced voltage, the rest died shortly after.  They don't make them like they used to..
Offline corndog71
Reply #9 on: May 08, 2014, 07:38:53 AM
If you're getting a lot of incessant ringing then chuck the tube.  Buy a bunch of 3S4 tubes.  They're cheap.
Rob
Online Doc B.
Reply #10 on: May 08, 2014, 09:52:06 AM
You could also try moving the preamp farther away from the speakers.
Reply #11 on: May 08, 2014, 09:53:18 AM
I hate to say this, but it seems Duracell batteries are made in China as well as in the USA. Some sellers offer both - the USA ones cost quite a bit more. The last time I looked, Costco was selling the Chinese ones.
It's only recently that I've heard anything bad about the Chinese batteries.
Offline marty51
Reply #12 on: May 08, 2014, 03:56:32 PM
Aha!  Thanks Paul.  Since I live in Taiwan, no surprises where these local Costco Duracells were made.  They are US80 cents a pop here.  Perversely, the 9V cells are working out fine.
Marty
Reply #13 on: May 09, 2014, 02:39:34 PM
I was at Costco today (in North Seattle) and all the Duracells they had were "made in America". Perhaps I remembered wrong, perhaps Costco cleaned up their act, perhaps Duracell acted to protect their brand, who knows? But from now on I'm checking the fine print before I jump on a bargain battery!
Prices were 14 D-cells for $14.79, and 8 9-volts for $15.89
Offline marty51
Reply #14 on: May 28, 2014, 11:52:48 PM
The 2 Quickies are up & running and they sound just wonderful.  I'd like to keep the battery concept but the above quality problems compound with both my Quickies in one chassis, quite apart from housekeeping 12 cells.   Yuasa SLA's are cheap here.  Would this idea work to provide the right voltages with 3 separate grounds?  The LM317 based reg boards have been suggested here before and at their price, not worth making oneself. Apologies for basic questions but as a mechanical engineer, I struggle with electrickery.
Marty
