charger · 4596
OK THANK YOU ! Does this means that Q is a low impedance preamp ?
Outputs of sources and preamplifiers need to be low. Some solid state products have an impedance like an Ohm or less. Tubed devices are higher, like the Quickie. They are at their best driving a higher load, say 10 times higher. This is why Bottlehead amps have a 100k Ohm or higher input impedance.
12,000 / 10 = 1,2001,200 < 2000 < 4000Numbers matter less than sound. These are rules of thumb, not laws carved in stone. If you are satisfied with the sound, then that is far more significant than any formula.
