Q impedance?
charger · 4606
Offline charger
on: March 11, 2014, 11:56:24 PM
what is Q impedance ? I can't find in the Q specs page
thank you
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Reply #1 on: March 12, 2014, 09:17:57 AM
Which impedance?
Input is about 100K, output impedance is 2K stock, and 4K with the PJCCS.
Offline charger
Reply #2 on: March 13, 2014, 03:18:33 AM
OK THANK YOU !
Does this means that Q is a low impedance preamp ?
Reply #3 on: March 13, 2014, 06:07:23 AM
Outputs of sources and preamplifiers need to be low.  Some solid state products have an impedance like an Ohm or less.
Tubed devices are higher, like the Quickie.  They are at their best driving a higher load, say 10 times higher.  This is why Bottlehead amps have a 100k Ohm or higher input impedance.
« Last Edit: March 31, 2014, 03:00:06 AM by Grainger49 »
Reply #4 on: March 13, 2014, 09:21:50 AM
OK THANK YOU !
How would you define a low impedance preamp?
Offline charger
Reply #5 on: March 14, 2014, 08:24:40 AM
I am using the Q to drive a class D amp with 12K Ohm impedance , do you think it's a good match?
Offline fullheadofnothing
Reply #6 on: March 14, 2014, 08:50:45 AM
12,000 / 10 = 1,200
1,200 < 2000 < 4000
Numbers matter less than sound. These are rules of thumb, not laws carved in stone. If you are satisfied with the sound, then that is far more significant than any formula.
Reply #7 on: March 14, 2014, 09:35:12 AM
12,000 / 10 = 1,200
1,200 < 2000 < 4000
Totally agree!
In fact, specific to the Quickie, if you put in the PJCCS the source impedance will double, as mentioned above - but the tube will see a much higher total load resistance and will perform better with lower distortion.
Reply #8 on: March 14, 2014, 10:13:42 AM
I agree with the adage, "Always trust your ears."
« Last Edit: March 31, 2014, 02:58:11 AM by Grainger49 »
