Problem with speedball upgrade
xiawei · 8117
Reply #15 on: March 25, 2014, 06:20:38 AM
I must emphasize that messing with the LED's on the socket is absolutely the last resort, and rarely an actual problem.
Please swap the smaller PC boards left to right and see if the issue follows one of the boards.
Offline xiawei
Reply #16 on: March 25, 2014, 08:43:27 AM
Good suggestion, I'll do after the work.
Offline xiawei
Reply #17 on: March 25, 2014, 08:45:42 AM
If your meter has a diode check position read the manual and see how it should be used.  Then check the LED.
If not, set it on a resistance range like 200 Ohms and check first with the red lead at the tube pin and the black lead on the socket center pin.  Better yet, put the black lead on the top plate; this verifies continuity to ground.  This reading should be a measurable resistance.  Report it back.
Then put the black lead on the tube pin and the red lead on the tube socket center pin you should have infinite resistance, or something above 1M Ohms.
Report your findings back.  We can at least verify that last LED and move on to the circuit boards.
I tried to do exactly as you are describing here. But I only managed to get reads from 3 out of 10 LEDs. Don't know why I can measure some even they light..
Offline xiawei
Reply #18 on: March 25, 2014, 12:16:45 PM
Thank you so much Caucasian! Now I see the hope!
After I switched the pc board, A3 lighted but A8 did not. Looks like it's the PC board. I also noticed they are always the LEDs on the faulty board light up first after the power is on.
But I already reosolder that board! Now how to pin-point the problem…
Really appreciate your help!
Online Doc B.
Reply #19 on: March 25, 2014, 12:21:19 PM
The transistors were possibly damaged by the A1/A2 short and may need to be replaced. You can request more at [email protected]
Offline xiawei
Reply #20 on: March 25, 2014, 12:26:42 PM
Thank you Doc!
You mean both the MJE350 and 2N2907?  Anyway to test them?
Reply #21 on: March 25, 2014, 12:29:09 PM
If you replace them, and the board works, then they were bad ;)
Really though, it's no problem to assist with some replacement parts, the transistors are sensitive enough that it's a good idea to replace them both and not worry about one failing later.
Offline xiawei
Reply #22 on: March 25, 2014, 12:32:32 PM
Thank you all for the great helps I got here! I'm ordering replacement now.
Offline xiawei
Reply #23 on: March 25, 2014, 01:06:47 PM
Sorry Doc just one more question! I switched the pc boards although A3 lights now but the sounds of both channels are gone. Before the switch the right channel sounded fine to me.
Could anything else be wrong?
Online Doc B.
Reply #24 on: March 25, 2014, 01:08:10 PM
Sure, but you need to make this fix before you move on to other issues.
Offline xiawei
Reply #25 on: March 26, 2014, 02:01:06 AM
Sent an email yesterday. How can I know the order was received?
Offline xiawei
Reply #26 on: April 01, 2014, 07:36:27 AM
Got the parts! The shipping was fast! Amazing service! Thank you Bottlehead!
 I'll install them either later today or tomorrow. And post the result here...
Offline xiawei
Reply #27 on: April 04, 2014, 03:49:38 PM
Thank you Doc for quick delivery of the parts. Unfortunately, after replacing both transistors on that small board, nothing changed! A3 LED still doesn't light up.
When the bad board was on the right side, terminal 5 read 0v and terminal 9 read about 50v. Now after switching of the boards (bad one on the left) and replacing of the transistors, T1 reads 0v and T7 reads 55v.
I'm puzzled! Please guide me!
Have a great weekend!
« Last Edit: April 04, 2014, 03:52:32 PM by xiawei »
Offline xiawei
Reply #28 on: April 07, 2014, 07:03:21 AM
Looks like it's the small board. But what also can go wrong with it? Or something else that is beyond my understanding? Please help.....
Reply #29 on: April 07, 2014, 08:57:56 AM
When we get our next batch of boards in, we can send you a single replacement board and all the parts.  (Since this has been narrowed down to be the issue)
I'd shoot an e-mail to replacementparts(At)bottlehead(doht)com
