Modifications to run e80cc/12bh7a/5687 for Crack+Speedball
kscwuzhere · 133727
Offline NightFlight
Reply #165 on: January 03, 2015, 06:20:49 PM
Oh yes.
Thanks CB and Paul for your input in this thread. Its appreciated.
Offline kscwuzhere
Reply #166 on: January 03, 2015, 10:32:42 PM
Oh yes.
Why not install a SPDT ON-OFF-ON so that you can roll between the 12au7, 12bh7a and the e80cc? That's what I did.
After rolling all these tubes at the right resistance I decided to retrofit for the 5687 and 7119 and I must say, I'm never going back to the 12au7, 12bh7a, and e80cc; the 5687 destroys these tubes. It has way better imagining and the soundstage is massive. Details and data retrieval are as good as the e80cc but it has the lower end warmth that the 12b7a had. After installing the 7119/5687 I found myself questioning why the Crack wasn't designed to run this tube in the first place. The way i retrofitted it also allows me to switch back to the 12au7 but I havent found myself ever wanting to.
Offline NightFlight
Reply #167 on: January 04, 2015, 08:58:08 AM
What are the potential (haha) drawbacks of trimpots in this application?  Cycle life is one I have seen so far.  But I'm looking for a fit with effectively infinite turn cycles. Say 100ohms in series with a 500ohm trimpot.
http://www.mouser.com/ds/2/428/accutrim1240-7897.pdf
Edit: OY! Price could be one issue.... An the Power Derating Curve...
« Last Edit: January 04, 2015, 09:09:55 AM by NightFlight »
Reply #168 on: January 04, 2015, 12:28:41 PM
Oh yes.
150 Ohms is about 6mA.  The voltage across the C4S is roughly 80V, and with 6mA of current, you'll dissipate 1/2 a Watt through the MJE-350.  A tiny heatsink probably wouldn't hurt here, and the MJE5731A will handle this with aplomb.
Reply #169 on: January 04, 2015, 12:31:27 PM
A trim pot would function here, though you'll end up with a fair amount of useless adjustment if you parallel the two when the trimmer is set to a low resistance.  A 100 Ohm resistor in series with a 500 Ohm/10 turn trimmer may work a bit better.
These are indeed expensive little buggers, and they would have to be glued down so that adjustments could be made reliably.
Offline NightFlight
Reply #170 on: January 05, 2015, 02:19:05 AM
I think I can just use some of the free space on the C4S board to get a 100 Ohm resistor in series with a trim pot easily enough.
Offline NightFlight
Reply #171 on: January 11, 2015, 05:33:03 PM
The MJE5731A and some cheaper cerment trim pots are on their way in the mail. You've definitely peeked my interest in the 5687 and they seem to be readily available. I have a about 5 flea-bay 12BH7's on their way as well.  It was hard to turn down 4 for $10 and a NOS Tung-Sol '59 milspec for $20. I'll give the 12BH7 a bit of a listen and then likely hard wire for the 5687 once I get the urge again.
I'd also like to re-cable my HD800, but I think I'll wait for the mainline. Then this crack stuff might become moot. :)
This photo initially lead me to believe an HD800 cable kit might surface from BH, but has yet to materialize:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fbottleheadnginx.bottleheadcorp.netdna-cdn.com%2Fwp-content%2Fuploads%2F2014%2F01%2Fmainlinehd800.jpg&hash=2bdd49d68e1d87de04d2f0a1ed7bbceba04181bd)
« Last Edit: January 11, 2015, 05:49:15 PM by NightFlight »
Reply #172 on: January 12, 2015, 05:38:52 AM
It's too difficult to hand build a reliable connection with those terrible plugs. My cable breaks each time we take it to a Head Fi meet. They really need a molded plastic strain relief.
Offline Jimb0
Reply #173 on: January 12, 2015, 09:33:42 PM
So I've been lurking on this thread and willing to try modding my crack for the 12BH7a and 5687's tubes but would still allow me to switch to the 12au7's.
From my understanding, I would need to get the following parts:
2 x DPDT On-Off-On
1 x DPDT On-Off-On
2 x MJE5731A
2 x HLMP-CB1A-XY0DD LED's
I'll also need to test out different resistors to see what matches the tube for my 12BH7's.
Could you guys tell me if I have any missing or incorrect parts?
Jim
« Last Edit: January 12, 2015, 10:00:52 PM by Jimb0 »
Offline kscwuzhere
Reply #174 on: January 12, 2015, 11:59:30 PM
2 x DPDT On-Off-On
1 x DPDT On-Off-On
2 x MJE5731A
Jim
Everything seems right to me. I recommend getting more RED leds and blue leds as they tend to break easily during construction. A simple resistor pack may be a good idea, as well as alligator clips to test them out.
Offline Jimb0
Reply #175 on: January 13, 2015, 08:11:43 AM
Thanks kscwuzhere,
Do you know where I can find the voltages for 12BH7's. What range is good to run them at?
« Last Edit: January 13, 2015, 10:21:48 AM by Jimb0 »
Offline kscwuzhere
Reply #176 on: January 13, 2015, 11:30:25 PM
Thanks kscwuzhere,
My 12bh7a ran perfectly at 70v with 140ohms
Offline Jimb0
Reply #177 on: January 15, 2015, 12:33:05 PM
Should all 12BH7a's run around that voltage?
Reply #178 on: January 15, 2015, 12:39:25 PM
I would be satisfied if ten 12BH7's that tested good hit that voltage (or thereabouts).  If only one 12BH7 was used to dial in the R1 value, then a worn or even an overly fresh specimen could throw things off a bit for the average tube.
Offline NightFlight
Reply #179 on: January 16, 2015, 12:03:31 PM
My first 12BH7A (unknown test value) hit 70v/75v @ 150ohm on R1. I dropped in MJE5731A to replace the MJE350 and they seem to work well enough as drop in replacements with no change to the output voltage.  Experimentally putting in cermet trim pots tonight. The trim pots I grabbed are 500ohm with 20 turns and seem to be stable to around .1 ohm at room temperature. We'll see how that goes once in the amp. I'm thinking in series with a 75ohm effectively in R1 to have more room to play with.
It definitely be nice to be able to dial in each side of the triode!;-)
