crackle and pop but no music [solved]
ike · 25439
Offline ike
Reply #15 on: April 16, 2014, 11:43:34 AM
You guys are awesome!  Thank you for your speedy diagnose and assistance.  I'll e-mail Eileen for the replacement parts for a new board.
You guys have a great day!
Offline ike
Reply #16 on: April 16, 2014, 11:57:29 AM
Just out of curiosity, why did the board fail?  About 4-5 months ago, I changed the 12AU7 tubes to 6SN7 tubes with a convert tube socket... Do you think that has anything to do the failure.
Reply #17 on: April 16, 2014, 02:09:45 PM
When the power line voltage is above spec (greater than 120v) the C4S feeding the shunt regulator dissipates a lot of heat. It's within spec but we had enough problems that we switched to the larger transistor not long after the upgrade board came out. At the same time, I increased the conservatism factors I use when designing! Often we saw scorch marks on the PC board, which was the first clue.
Offline ike
Reply #18 on: April 26, 2014, 09:54:12 AM
Hey guys,
Just a quick update, I installed the new replacement board this morning.  Music is back in the house!  Thank you PB and everyone.
Reply #19 on: April 26, 2014, 07:42:57 PM
Hello Ike,
Thanks for popping back in to let us know it all worked out!
