Choke specs for the Crack
JamieMcC · 51747
Offline JamieMcC
on: April 04, 2014, 01:43:03 AM
I am considering whether to do the 12au7 choke mod on my crack and replace the last electrolytic capacitor with a film one.
Looking around at what 12au7 chokes are on offer I noticed there is quiet a difference in specs and prices.
Is there generally a favoured type re materials & performance specs brand etc that I should look out for when considering. I am guessing all chokes are not created equal even though they may look similar and marketed as the same?
Reply #1 on: April 04, 2014, 02:27:23 AM
Are you going to put a choke in the power supply or as the plate load for the 12AU7?
If in the power supply the Triad C7-X is often used.
« Last Edit: April 04, 2014, 04:56:18 AM by Grainger49 »
Offline JamieMcC
Reply #2 on: April 04, 2014, 04:32:39 AM
Thanks that was handy I entered the Triad C7-X in the search box and found a useful thread on the topic. I belive the mod is replacing the resistor on the last cap in the power supply with the choke this would enable the Electrolytic cap 220uf to be replace with film cap uf? from my reading I picked up 4x 50uf F&T film caps the other day for not much money and thought I might try them in this configuration. I use sen HD650 and Beyer T1 so 300ohm & 600ohm impedance thought about trying them configured as 100uf-150uf-200uf it would be relatively easy and a bit of a exercise in how the sound is effected with differing values.
http://bottlehead.com/smf/index.php/topic,3498.msg30912.html#msg30912
Edit I'm thinking paralleling them up to achieve the different uf values will be fine?
« Last Edit: April 04, 2014, 04:53:43 AM by JamieMcC »
Reply #3 on: April 04, 2014, 04:58:37 AM
It is my understanding that if you replace the final cap with a film you need not use the same value, uF.  So a 100uF or 150uF film will be a good replacement for a 220uF electrolytic.
Reply #4 on: April 04, 2014, 05:46:50 AM
Jamie, you could have hours of fun playing with this http://www.duncanamps.com/psud2/ comparing the resistor to choke, different cap values, and see what effect each one has.  I learnt a lot from it when building the supply for my AC quickie as some of the results were not at all obvious.  Sometimes adding more capacitance actually made things worse, and using the simulator i was able to work out optimum ranges of capacitance and resistance for each position for a given load.  Its a bit of a black art and i dont pretend to understand the math or theory behind the half of it, but it helped me cobble together a very quite and effective power supply with the exact voltage i needed at the output.
Offline JamieMcC
Reply #5 on: April 04, 2014, 06:37:57 AM
Mark thanks for the link I will have a play with that later and see if I can make any sense out of it.
Reply #6 on: April 04, 2014, 07:30:59 AM
Just had quick play with it, i dont have the exact details for everything but i'm estimating ~1.5mv ripple with the three 220uf caps as stock, with a C-7X choke i kept lowering the capacitance until i got back to ~1.4mv ripple and was using 220uf, 100uf, and 22uf so certainly getting into the ballpark where film caps are feasible.   Of course ripple is only one part of it, there are many other factors to consider but as far as i know film caps will be better in those areas too.  You have me thinking about the final 22uf caps in the S.E.X. supply now :)
I can post the two PSD files i made if the BH guys have no complaints, i assume there is an unwritten rule about not posting schematics or manuals bits on the internet?
Offline galyons
  • Geary Lyons
Reply #7 on: April 04, 2014, 07:32:35 AM
I have a Triad C7X in my 7N7 Crack.  It made a very noticeable improvement in the reduction of background noise, better low level detail and timbre.  The final PS caps are the same aluminium foil with waxed paper caps as the output.  I run 60uF output (200 ohm & 600 ohm phones) and 30uF, (actually 32.2 with K5 bypass!), for final PS.  The finals value was a trade off, better cap versus more capacitance.  Real estate made the final decision for me.
Cheers,
Geary
« Last Edit: April 04, 2014, 04:37:57 PM by galyons »
Offline JamieMcC
Reply #8 on: April 04, 2014, 08:01:51 AM
Geary, thanks for your input, am I missing anything in my assumptions that once the relevant resistor is removed the choke leads are soldered in to the same position as the resistor so effectively just a substitution all be it one that takes up more space?
Jamie
Offline galyons
  • Geary Lyons
Reply #9 on: April 04, 2014, 08:27:41 AM
Jamie
Not missing a thing.... 270 ohm for 270 ohm and much more space!
Cheers,
Geary
Offline galyons
  • Geary Lyons
Reply #10 on: April 04, 2014, 08:47:30 AM
...The finals value was a trade off, better cap versus more capacitance.  Real estate made the final decision for me.
Cheers,
Geary
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FLqyI9pG.jpg%3F1&hash=50d14853ed6fd890581466b9a349d6c9f8a62ac9)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FvTQTH1Q.jpg%3F1&hash=fd71624c092c659c987e45be9e15379be52ef8f7)
Offline JamieMcC
Reply #11 on: April 04, 2014, 08:48:58 AM
Super thanks this is the one I am looking at
http://www.ebay.co.uk/itm/Triad-C7X-10H-90mA-smoothing-choke-/171093411086?pt=UK_Sound_Vision_Valves_Vacuum_Tubes&hash=item27d5f6450e
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.ebayimg.com%2Ft%2FTriad-C7X-10H-90mA-smoothing-choke-%2F00%2Fs%2FMTIwMFgxNjAw%2Fz%2F2pUAAOxyYSJR-35Y%2F%24%28KGrHqF%2C%21ncFH105MFgoBR-35%280ykw%7E%7E60_58.JPG&hash=deb03ac2ddaec521cd287f98c82ced52af041404)
Offline JamieMcC
Reply #12 on: April 04, 2014, 08:58:56 AM
Geary, thanks love the picture and see you have been quiet creative in installing them, nicely done by the way quiet impressive actually.
Do you like how they working out any particular strengths?  I also noticed you have not gone down the speedball route any particular reasoning behind that?
Its just interesting to hear about different approaches
Offline galyons
  • Geary Lyons
Reply #13 on: April 04, 2014, 08:59:42 AM
Offline galyons
  • Geary Lyons
Reply #14 on: April 04, 2014, 09:08:45 AM
They are strong in imaging and timbre.  I am a PIO guy. I tried some MPP & MPP in oil, but just not to my taste.  Speedball is awaiting BH shipping.  I ran my AU7 Crack for quite awhile before doing the Speedball.  The Speedball is an improvement, but there is, to me, a trade off, better detail for less warmth.
Thanks for the kind words!
Cheers,
Geary
