First Time Crack Builder Need Assistance [solved]
prtuc2 · 16581
Reply #60 on: May 26, 2014, 11:45:06 AM
Hmm, try running the amp without the 6080 to see if the voltages at terminals 1-5 look to be about correct.
Offline prtuc2
Reply #61 on: May 26, 2014, 12:11:35 PM
Terminal 1-5 voltages shown as 0.  The 6080 tube is taken out and the 12AU7 tube isn't lighten up either.  I am sure there is power cause I got a shock accidentally touching the power supply.
Reply #62 on: May 26, 2014, 02:12:44 PM
If the 12AU7 isn't glowing, then there is an issue with the twisted pair of wires going from power transformer terminals 4 and 5 to B7/B8 and A4,5/A9.
We have been seeing some builders lately who accidentally cut one of the wires coming out of the transformer itself, so that's worth looking at as well.
Reply #64 on: May 26, 2014, 05:21:29 PM
If the 6080 is in the socket, does it glow?
Offline prtuc2
Reply #65 on: May 26, 2014, 05:46:08 PM
Both tubes does not glow, seems the current is not going through the socket.  Matter of fact the led does not glow, before the problem occurred all the led lit up just fine.
Reply #66 on: May 27, 2014, 04:59:24 AM
What is the AC voltage between power transformer terminals 4 and 5?  (Put one probe on each terminal)
Offline prtuc2
Reply #67 on: May 27, 2014, 09:01:00 AM
Both terminal AC voltage is 0.  Seems no power is going through the unit, could it be the power cord module overheat or damage?
Reply #68 on: May 27, 2014, 09:13:11 AM
What about the AC voltage between power transformer terminals 1 and 2?
Offline prtuc2
Reply #69 on: May 27, 2014, 09:38:22 AM
All the terminals include the B socket and A socket all the AC voltages are at 0.
Except B6 and terminal 9U both show 0.588V, B6 is connected to 9U and that is the only spot on the amp actually got any voltage reading, while the rest of the amp is at 0.
Reply #70 on: May 27, 2014, 07:51:50 PM
Power transformer terminals 1 and 2 receive the incoming AC line voltage.  If you have 0V there, your amp isn't plugged in, your power switch is off (or melted), or your fuse is blown.
Offline lordnikon
Reply #71 on: May 28, 2014, 03:52:20 PM
Your picture below indicates you have the wrong orientation of the Speedball PCB board (with the large heat sinks) The printed words "TOP" should be facing south towards the 12AU7 socket and not the 6080 socket.
http://s828.photobucket.com/user/prtuc2/media/P1000273_zpsc6f95926.jpg.html
Offline prtuc2
Reply #72 on: May 28, 2014, 04:31:52 PM
I have been suspecting the power switch probably melted when I desoldering the solder iron, just going to re-order an exact pair of fuse and power switch to see if that was the problem or not.
Thanks for pointing out my large PCB is reversed, I will fix it this weekend.
Really appreciate all the help, so far.
Reply #73 on: May 28, 2014, 06:58:14 PM
The board is functionally the same in either orientation, and will work provided you have the connections attached in the correct positions.
Offline lordnikon
Reply #74 on: May 28, 2014, 07:26:26 PM
I came across the same problem as I reversed the orientation of the Speedball PCB. The LEDs didn't work. Once I rotated the board, it worked.  ???
