High voltage on terminal 1
pdrm360 · 7099
Offline pdrm360
on: April 13, 2014, 12:42:27 PM
I have scratchy/crackling sound issues with my Crack + speedball.  After the voltage check I found a high variable voltage (140~190 VDC) on the terminal 1, B1 and B4.  What could be the issues?  Thanks!
« Last Edit: April 13, 2014, 08:55:26 PM by pdrm360 »
Reply #1 on: April 13, 2014, 04:24:51 PM
Sounds like a loose connection.
Offline pdrm360
Reply #2 on: April 13, 2014, 05:19:15 PM
Could a bad tube be cause of this issues?
Online Paul Joppa
Reply #3 on: April 13, 2014, 05:33:51 PM
Check the other voltages, especially the 12AU7 socket. Do the tube heaters glow? LEDs?
Offline pdrm360
Reply #4 on: April 13, 2014, 06:30:16 PM
Terminal/Voltage(VDC)
1. 80~190
2. 180
3. 0
4. 184
5. 75
6. 0
7. 182
8. 0
9. 111
10. 0
A1 76
A2 0
A3 1.6
A4 0
A5 0
A6 182
A7 0
A8 1.6
A9 0
B1 80~190
B2 185
B3 180
B4 75
B5 185
B6 110
B7 0
B8 0
The LEDs in the the 12AU7 socket are lighting fine
The right side LED on the A board is blinking
The left side LED on the A board and the LEDs on the B board have a very low light.
Offline pdrm360
Reply #5 on: April 13, 2014, 06:55:05 PM
I haven't found any loose connection and the tubes heaters glow.
Reply #6 on: April 14, 2014, 05:21:46 AM
This sure sounds like a loose connection, or a flaky solder joint.
Offline pdrm360
Reply #7 on: April 14, 2014, 07:50:19 AM
Thanks everyone!
Are suspected in an area or part of the loose connection?  I've not found any  loose connection so far.  :-\
Reply #8 on: April 14, 2014, 08:34:30 AM
You can try swapping the small boards right to left, if the voltage issue migrates to terminal 5, you have a flaky connection on the board.
If it doesn't move, you have a flaky connection at A8, A7, or A6, and the parts those connect to.
Offline pdrm360
Reply #9 on: April 14, 2014, 08:49:49 AM
Will do.  Thanks for your help and guidance!
Offline pdrm360
Reply #10 on: April 14, 2014, 04:16:23 PM
I swapped the small boards. Here are the new voltages:
1. 79
2. 194
3. 0
4. 195
5. 75
6. 0
A1 80~100+
A2 0
A3 1.6
A4 0
A5 0
A6 79
A7 0
A8 1.6
A9 0
What do you think? Thanks!
Reply #11 on: April 14, 2014, 05:12:08 PM
Since A1 is connected to terminal 5, can you see if the voltage is jumpy there also?
Offline pdrm360
Reply #12 on: April 14, 2014, 06:54:10 PM
Yes, the voltage is jumpy.
Update: I removed the Speedball, now the Crack is working fine.
It looks one of the TIP-50 transistors has a issues, the left side lead and the right side one have connectivity from both sides. I'm not sure if it's all the Speedball issues though.
Reply #13 on: April 14, 2014, 07:18:52 PM
The TIP-50 transistors are on the larger PC board, which seems to be OK.
I believe you may have a flaky solder joint on that small PC board that is now feeding terminal 5.
Offline pdrm360
Reply #14 on: April 14, 2014, 07:38:22 PM
Two of the LEDs on the larger board didn't have light.
I've checked the all the joint connections on the small boards, but Yes, the A board doesn't work as same as the B board.
