Bottlehead Kits
Legacy Kit Products
Smash
Dimension checks
Dimension checks
mpeg2
7929
mpeg2
Full Member
Dimension checks
April 23, 2014, 06:22:51 AM
I've pre-ordered a Smash kit. I plan to make a base & turn some knobs in the time between now & when it ships.
If I read correctly, the plate is 10" x 10" - correct?
Can someone tell me the diameter of the pot shafts?
Rich
Paul Birkeland
Global Moderator
Hero Member
Re: Dimension checks
Reply #1 on:
April 23, 2014, 06:24:50 AM
Yes, the base plate is indeed a 10x10.
The pot shafts are 1/4".
Have fun making the knobs!
mpeg2
Full Member
Reply #2 on:
April 23, 2014, 06:32:46 AM
Thanks.
Lathes are fun, you just hold the tools or sandpaper & the lathe does all the work.
Did a set for my Stereomour - turned out quite nice.
Rich
xcortes
Sr. Member
Reply #3 on:
April 23, 2014, 07:49:22 AM
"Lathes are fun, you just hold the tools or sandpaper & the lathe does all the work."
I don't think that my friend that builds 1.2 meter diameter horns in his self built lathe agrees!
Xavier Cortes
Bottlehead Kits
Legacy Kit Products
Smash
Dimension checks
