Help needed to stop blowing fuses
Loquah · 10017
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
on: May 02, 2014, 08:06:54 PM
Hi all,
I'm currently trying to salvage a bit of a mess. A friend of mine tried to build a SEX, but has made a bit of a hash of it (no offense intended to him).
After rebuilding the obvious issues, I've tested the resistance and everything is ok, but the SEX keeps blowing fuses. I've tried testing for shorts in the power circuit, and the first thing I'm wondering is if (testing from the main earth near the power inlet) 0.4 ohms at the transformer terminals 4 and 5 is my issue.
Any other suggestions for tracing a fuse-blowing short when all resistance checks are fine and there are no visual signs of shorts?
Reply #1 on: May 02, 2014, 08:20:45 PM
Is it instantly blowing when you try to power up?  Do you see the heaters starting to glow?
 .4 ohms is so low it doesn't sound like the issue to me, but i might be wrong.  What do 1 & 2 read?
As usual post some close up pics if you can, fresh set of eyes might spot something...
Offline Loquah
    • Passion For Sound
Reply #2 on: May 02, 2014, 08:48:06 PM
Thanks Jamie.
Terminals 1 & 2 have infinite resistance measured from T23.
The fuses blow instantly with no sign of glow from the tubes.
Should there be something lower than infinite resistance between transformer terminals 6&7 and either transformer terminal 1/2? I'm wondering if the transformer was buggered during initial power up.
Here are some picks. Sorry about the mess - I'm trying (in vain) to clean up as much as I can without a full rebuild.
Reply #3 on: May 03, 2014, 04:40:40 AM
Sorry, going back to your original post, i assumed when you said terminals 4 & 5 you were talking about the heater supply not the high voltage supply. The HV supply terminals should give you a very high reading and changing as the caps charge from the meter. From my notes i was seeing over 100k and counting so .4ohms is certainly not right. I dont see anything obvious in the attached pic, can you post a few more from further down the power supply trail..
Also double check the heater diodes, one of them i cant really see but the leads for the two going to terminal C5 look very close together, just make sure none of them are contacting each other.
Are you 100% the rest of your resistance measurements are within spec?
P.S. I'm Mark, Jamie is the other one who posts too much :P
Reply #4 on: May 03, 2014, 08:07:57 AM
The filament winding (terminals 4 and 5 of the power transformer) are grounded, so those measurements are fine.
The first thing to check is the DC resistance at the power cord. You should see infinite resistance with the power switch Off, and around 10 ohms with it On. If you pass this test, then you can eliminate the input power wiring and the power transformer primary. If you don't pass this test, then stop here and we'll help you trace the fault in the primary power wiring.
Once you've confirmed the primary wiring as above, and if you have not tested it without tubes, do so now. I assume you have a stock of spare fuses, we may go through a few in this process! If the fuse still blows then there is a problem in the power supplies; if the fuse does not blow then the power supplies are not at fault.
I think it would just make this post confusing to offer next steps, because they depend too much on the results of the above tests. Report back and we'll keep working!
Offline Loquah
    • Passion For Sound
Reply #5 on: May 03, 2014, 11:56:59 AM
LOL. Sorry, Mark! I do know the difference between you and Jamie, but I think in my tired state and having had so many great discussions with you both about caps and attenuators, the two of you temporarily became one in my mind.  ???
I checked the diodes after my post because I was wary of them too, but all is clear despite being close. I've moved them a little to create more space as well.
All other resistance checks are 100% within spec.
Offline Loquah
    • Passion For Sound
Reply #6 on: May 03, 2014, 12:02:04 PM
Thanks Paul. I have plenty of fuses (1A quick blow - is that ok?)
I've tried testing the power socket this morning, but not sure if I'm doing it right so I'll share my process:
1. With switch off I measured resistance between earth (chassis screw) and the three pins in the power socket. Readings are E: <0.5ohms, L: infinite, N: infinite
2. With switch on the same readings create the exact same results. Is this the issue?
Notes: no connection to the power cable and mains outlet for this test. A fresh fuse was installed and intact.
Offline Chris65
Reply #7 on: May 03, 2014, 02:04:01 PM
Those readings are correct, as you're measuring with reference to ground.
What you want to measure, with the unit unplugged, is between L and N: OL with switch off, & around 10 ohms with the switch on.
Offline Loquah
    • Passion For Sound
Reply #8 on: May 03, 2014, 02:40:25 PM
Oh, cool. Thanks Chris!
9.4 ohms when switch is on. Infinite with switch off.
Reply #9 on: May 03, 2014, 03:14:01 PM
Then you are good on the primary side of the transformer.  The problem must exist on the secondary side.
I don't know if it has been mentioned, but backward caps can blow the fuse.
Offline Loquah
    • Passion For Sound
Reply #10 on: May 03, 2014, 03:20:11 PM
I've checked a lot of the caps, but I can't promise that I've checked all of them. One of the biggest issues with this build is the fact that many items were installed with incorrect alignment so there's a strong chance that there's a cap causing the grief. I'll check and report back.
In the meantime, what should I measure next?
So far I've checked the Schottky rectifiers and all are reading as though they're undamaged and I've confirmed that they're correctly oriented. I have tested for shorts to earth along the various power lines (6.3V heater power and main power), but not sure if I should be looking for something other than a short to earth.
Offline Loquah
    • Passion For Sound
Reply #11 on: May 03, 2014, 03:42:25 PM
Confirmed that all caps and diodes are correctly oriented.
Offline kgoss
Reply #12 on: May 03, 2014, 03:43:50 PM
Try a slow blow fuse if you have or can get one. Same amp rating as the stock fuse.
Ken
Ken Goss
Offline Loquah
    • Passion For Sound
Reply #13 on: May 03, 2014, 04:01:45 PM
Is the stock fuse with the S.E.X. fast or slow acting? I have the fuse that's in my personal S.E.X. but I thought they were fast fuses that are provided.
Offline Chris65
Reply #14 on: May 03, 2014, 05:01:39 PM
Yes, try a slow-blow fuse. Found this thread which suggests the same:
http://bottlehead.com/smf/index.php/topic,974.msg7176.html#msg7176
