Power Transformer Residue
Exaliftin · 2190
Offline Exaliftin
on: May 24, 2014, 05:51:11 AM
I am wondering if it is normal to have this all over the transformer and is there an easy way to clean it off? Thanks
Reply #1 on: May 24, 2014, 06:38:15 AM
Yes, it is very normal, this varnish is what holds the transformer together.  If you use a solvent to remove it, you will risk having the transformer delaminate on you.
Most folks just paint right over it with a flat black paint.
Offline Exaliftin
Reply #2 on: May 24, 2014, 06:49:08 AM
Thanks for the quick response
Offline johnsonad
Reply #3 on: May 24, 2014, 07:46:21 AM
It goes without saying but make sure you tape off the areas before painting. The cardboard braces that come with the transformer work great when painting.
Reply #4 on: May 24, 2014, 07:52:59 AM
Place a piece of sandpaper on a hard flat surface like a pane of glass, then slowly sand the sides of the transformer to remove any excess varnish.  That will leave you a nice clean surface which once painted will look perfect.
