Bottlehead Kits
Crack
Power Transformer Residue
Exaliftin
2187
Exaliftin
Newbie
May 24, 2014, 05:51:11 AM
I am wondering if it is normal to have this all over the transformer and is there an easy way to clean it off? Thanks
Paul Birkeland
Global Moderator
Hero Member
Re: Power Transformer Residue
Reply #1 on:
May 24, 2014, 06:38:15 AM
Yes, it is very normal, this varnish is what holds the transformer together. If you use a solvent to remove it, you will risk having the transformer delaminate on you.
Most folks just paint right over it with a flat black paint.
Exaliftin
Newbie
Reply #2 on:
May 24, 2014, 06:49:08 AM
Thanks for the quick response
johnsonad
Hero Member
Reply #3 on:
May 24, 2014, 07:46:21 AM
It goes without saying but make sure you tape off the areas before painting. The cardboard braces that come with the transformer work great when painting.
mcandmar
Hero Member
Not all engineers are civil
Reply #4 on:
May 24, 2014, 07:52:59 AM
Place a piece of sandpaper on a hard flat surface like a pane of glass, then slowly sand the sides of the transformer to remove any excess varnish. That will leave you a nice clean surface which once painted will look perfect.
Bottlehead Kits
Crack
