Yeah! Built my Crack! Need to pad down my volume- PICTURE POSTED
Nathan · 8645
Offline Nathan
I ordered my Crack in April- took about 3 weeks to arrive. The day it arrived I assembled the base. The following day I did the mechanical work - ie, mounting the switches, transformer, etc. the only issue I had their was that I wasn't sent enough small nuts. Easy enough trip to the hardware store fixed that. I spent two evenings soldering. My years being an avid modeler when I was younger paid off as you need to be patient and meticulous.
The base was machine sanded, stained with 2 coats of Sedonna red, then 3 coats of semi gloss polyurethane ( sanded between coats).
All resistance checks were spot on, as we're all voltage checks. I used a Hakko soldering station and Cardas solder. All solder joints look shiny.
The moment of truth- plugged it is and give it a listen. First tried an inexpensive pair of cans and I got sound. Next came the HD600's. Perfect! At any sane listening levels there's zero noise. Sure if I have no music paying and the volume is jacked way up, there's hum but that's not realistic.
Color me very impressed.
Only one issue- with my HD600's, the total rotation of the volume knob from silent to loudest I can bear is 1/6 rotation of the volume knob at best. Time to solder in some resistors. I see the FAQ section covers this and suggests either 270k or 470k resistors. Though I have both value resistors, I'm curious if other with  HD600's have encountered the same thing and if so what value they have used
« Last Edit: June 15, 2014, 10:37:10 AM by Nathan »
Crack/Speedball & SEX 2.1/C4S
Reply #1 on: May 28, 2014, 06:44:08 PM
You'll generally have better luck if you spend the big bucks and get 4 resistors.  I would put a 33K across the outer pair of lugs on each level, and a 75K in series between each center post on the RCA jacks and the wire connected to them.  This will give you some serious padding, as well as maintaining a reasonable input impedance.
Offline Nathan
Reply #2 on: May 28, 2014, 09:27:09 PM
thanks for the suggestion-
if you could, as I am very good at following directions  but am not well versed in building electronics, if somehow you could provide some sort of wiring diagram for the 75k ohm and 33k ohm resistors, that would be greatly appreciated
Thanks- Nate
Reply #3 on: May 29, 2014, 06:35:53 AM
Nathan,
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2Fttiwwp.gif&hash=e7ff13cc08d6091a1bf54867d2dfd1da75ce755a)
I want to see the base!
Let's see if I can give you different instructions.
At the input RCA jacks remove the wires going to the center of the jack, insert one end of a 75k Ohm resistor and solder the wires back to the other end of the 75k Ohm resistor.  That puts the resistors in series with the signal "hot."
Then at the volume control, you have three lugs one set on top, one set closer to the plate.  If I have this right, Paul is saying to go from the input lug (from the RCA jacks) to the ground connection of each set of three.  Those are the outer lugs, the center lug of each trio goes to the 12AT7.
Reply #4 on: May 29, 2014, 08:37:17 AM
There is a pretty good diagram on this webpage that you can look over:
http://www.goldpt.com/mods.html
Reply #5 on: May 29, 2014, 09:32:26 AM
If you understand what I wrote that is exactly what is on the link.
« Last Edit: May 30, 2014, 01:07:53 AM by Grainger49 »
Offline Nathan
Reply #6 on: May 29, 2014, 03:00:11 PM
Ok, I get it- 75k on series with  the hot RCA pins, then the 33k across the outer lugs on both levels of the volume pot.
Offline SammyJ
Reply #7 on: June 02, 2014, 06:27:28 AM
Nathan,
+1 -- take a pic!  I want to see this Sedona base!
Offline Nathan
Reply #8 on: June 03, 2014, 04:51:53 AM
I'll do the picture- hopefully later today- it came our real purty
Nathan
Offline Nathan
Reply #9 on: June 04, 2014, 10:53:02 AM
The forum's FAQ suggests thus to pad down the volume -
"3.  I can barely turn my Crack up at all before it's far too loud, what do I do?
Remove the white wire from the left RCA jack at the rear of the chassis.  Solder in a 270K resistor to the solder cup on that jack, solder the white wire to the other end.  Repeat this for the red wire with another 270K resistor.  This will give you about a -10dB pad at the input.  If you still have the issue, try 470K instead.  The wattage of these resistors isn't all that important, anything between 1/16 Watt and 1/2 Watt is reasonable, with metal film and carbon film types being most recommended."
Why is the suggestion here of 2 33k ohm resistors across the outer lugs of the volume control and a 75k ohm resistor in series with each of the  hot pins of the RCA's a better solution?
Reply #10 on: June 04, 2014, 10:57:52 AM
Offline Adrian
Reply #11 on: June 05, 2014, 03:12:22 AM
Seems like it would be appropriate, but I must ask:
Will this 2-33K and 1-75K per channel resistor combination be a good way to "pad" the volume on the S.E.X. 2.1?
Adrian C.
Reply #12 on: June 05, 2014, 06:40:06 PM
Yes, the same logic applies, though I believe you would be the first person to pad down the level control the SEX.
Offline Nathan
Reply #13 on: June 10, 2014, 05:15:47 PM
Ok, installed the pair of 75k resistors in line with the hot pins and the 33k resistors as instructed- not the neatest job as the  volume control area was already crowded. Wondering if I wanted a little less padding down what value resistors I should use? Really don't want to change the 33k ones as they were pain.
Reply #14 on: June 10, 2014, 06:12:23 PM
Try 50K in place of the 75K.
