Devore Fidelity & Paramount
jaragon · 8787
Offline jaragon
on: April 21, 2010, 03:09:35 PM
Hi everyone. Do any of you pair the Paramount with a Devore Fidelity Speaker. I own the Super 9s which are rated at 90.5db. A Shindo Montille - push-pull at 15 watts - drives them easily. I think the Paramount's 8/9 watts may be just straddling the line. I live in mid-size apartment. Any advice would be greatly appreciated. Thanks.
Reply #1 on: April 22, 2010, 03:19:50 AM
Admittedly the sensitivity of your speakers is under what Bottlehead recommends.  But... always the but, there are several things that factor into this.
How big is your room, how hard/soft is your room, how loud do you like to listen and what kinds of music do you listen to?
If you have a 20' ceiling in a 32'X18' room (obviously you don't), your room is overly damped, you like to listen to hard rock at concert volumes then you will be in trouble.  Considering that a 15WPC tubed PP amp now increases your chances.  Your other thread will help also.
Offline dmannnnn
Reply #2 on: May 04, 2010, 03:26:18 PM
I have had great results with 8watt SET and 90 or 91db speakers.  Enough power even for a good sized room.  The marantz HD770's I'm using now are 89db and they get much too loud with the paramounts.
Harmon Kardon T60 - Hagerman Bugle - Cal Audio Labs CL15
ForePlayIII - Paramount 300B's
Klipsch RF-7/Altec Model 14/Magnepan MG12
Reply #3 on: May 05, 2010, 12:18:16 AM
I didn't mean to discourage him.  According to the numbers my room doesn't work but it does for me.  But the OP hasn't posted back.  He might not be watching any more.
