Bam!
Doc B. · 97750
0 Members and 4 Guests are viewing this topic.
Offline murray
Reply #15 on: June 21, 2014, 07:01:03 PM
@Natural Sound:
Do you know how many watts you can get with the 12 volt supply?
Murray S. (N.Z.)
Offline Tubejack
Reply #16 on: June 22, 2014, 04:56:19 AM
There are 10 types of people in this world,
Those that understand Binary and those that Don't!
Offline Natural Sound
Reply #17 on: June 22, 2014, 11:07:02 AM
@Natural Sound:
No, I have no way of measuring that. The Bottlehead circuit is different from what I'm using so it's a moot point anyway.
Reply #18 on: June 22, 2014, 12:21:13 PM
I'm sure that PB will jump in here and correct me if I'm wrong. The TPA3122 will run on 10 to 30 volts. Operating the chip at lower voltages will produce a little less power. I'm running a TPA3122 on a single 12 volt SLA behind a quickie. It sounds great in my shop where I don't require a ton of power.
Yes, this is true.  (The chip actually seems to run OK on 9V as well)
Offline Bonzo
Reply #19 on: June 22, 2014, 08:24:29 PM
Will it be possible to use a (good) 18vdc switching psu?
Will this deteriorate sound quality too much?
Thank you
Bisogna avere orecchio!
Reply #20 on: June 24, 2014, 04:07:15 AM
I suspect that the 18V switching supply will work, but that the sound quality will deteriorate greatly.
There are some good papers available online that go into what happens in a switching supply when you operate outside of the rated supply current.  Essentially, things are really bad at either end, and a Class D amp is going to run you into the low end and high end of current demand frequently.
Offline Bonzo
Reply #21 on: June 27, 2014, 12:01:17 AM
Got it!
What about input sensitivity? It would be lovely to mate it with a quickie, but I noticed chip amps needs attenuation rather than amplification of the input signal
PS:Any underside pics? ;-)
Ciao!
Reply #22 on: June 27, 2014, 03:42:01 AM
IIRC, gain is right around 20dB.  Since the Quickie isn't a particularly high gain preamp, they are a well suited match.
Offline Bonzo
Reply #23 on: June 27, 2014, 05:16:42 AM
Thank you very much Paul!
Offline johnsonad
Reply #24 on: June 27, 2014, 12:50:41 PM
Nice one! I look forward to hearing it!
Offline aragorn723
Reply #25 on: June 30, 2014, 03:25:44 PM
How well would this amp do with 24V instead of 18?  2 12 volt SLAs would be a nice battery choice for this :)  I like my current SS power amp but this is kinda intriguing!
Dave
Reply #26 on: June 30, 2014, 04:45:47 PM
The amp will run on anything from 10 to 30 volts, just like it says a few posts up.
Offline satbaba
Reply #27 on: June 30, 2014, 07:22:58 PM
Sennheiser HD800 compatible?
I'm still using crack OTL + speedball
Reply #28 on: July 01, 2014, 04:50:43 AM
Reply #29 on: July 01, 2014, 05:00:06 AM
Thanks for all of the Quicksand orders the past 24 hours! The guys will be photographing the assembly today for the manual. We should have the oft requested underside photo very soon.
