Bam!
Doc B. · 97989
Offline Cary
Reply #30 on: July 01, 2014, 03:45:26 PM
Just ordered mine yesterday, it will be demonstrated at the Northern California DIY show in October.
« Last Edit: July 01, 2014, 03:49:09 PM by Cary »
Offline Magnetron
  • I took things apart when I was a kid.
Reply #31 on: July 01, 2014, 06:49:36 PM
I have been OK with the low power, unmodded tripath chip amps with the quickie in my bedroom stereo, I anxiously await the bottlehead quicksand.
P. Bond
Reply #32 on: July 02, 2014, 12:01:25 PM
First post edited to add a picture of the underside of the completed amp.
Reply #33 on: July 02, 2014, 01:24:39 PM
I think that there is room for bypass caps and upgraded output caps there.
It is tiny.  Not at all like my ChipAmp Gain Clone.
Offline WK3K
  • Beginning to see the light...
Reply #34 on: July 03, 2014, 06:25:17 AM
Looking at how clean the underside is, my first thought is: Can this be built into the same chasis/enclosure as the quickie...
Only one way to find out!
 ;D
Witold
Rega P3-24 w/ Rega Exact > Eros II> Quickie w/PJCCS > Stereomour II w/ DC filament supply > Blumenstein Orca Mini/Max 2.1
MacBook > Grace SDAC > Crack w/ Speedball > Sennheiser HD6XX
Offline denti alligator
Reply #35 on: July 03, 2014, 06:29:19 AM
 ;D
I don't see how, unless you planned on making the plates at 90-degree angles to one another or on opposite sides of the chassis. But you could probably just saw your Quickie chassis in half (horizontally, of course) and use the two pieces for the two amps.
- Sam
Offline WK3K
Reply #36 on: July 03, 2014, 06:57:45 AM
I was thinking more along the lines of mounting the PCB to a standoff on the underside of the quickie chassis, hardwiring the quickie output into the quicksand input, then installing the various audio outs and power switch into the base itself. The only problem will be figuring where to mount all those batteries. Maybe on the inside of the base itself...
Witold
Reply #37 on: July 03, 2014, 09:40:18 AM
I think it is a natural progression.  But the problem I see is all those batteries!  The Quicksand has 95% of the top of the chassis covered with batteries.
Maybe put the Quickie batteries under the top and the Quicksand batteries on the top?
If you lead others will follow.
Reply #38 on: July 03, 2014, 09:44:12 AM
Yeah, there are a lot of batteries!
Offline kgoss
Reply #39 on: July 03, 2014, 10:57:30 AM
Since battery power is what makes this amp special and there are so many to replace, maybe Bottlehead will offer an upgrade kit to run it from SLA batteries. Something like the upcoming DAC if that would work. Not that those are small, but they could charge when you weren't listening. Anyway just a thought.
Ken Goss
Offline Sonido
Reply #40 on: July 04, 2014, 01:20:22 PM
I just saw the picture of the underside and circuitry, and it looks to have a shared/common ground. I thought Class D/T amps didn't have a shared ground? When I was messing with the HE-500 with speaker amps, one of the limitations on using a speaker tap to TRS adapter was the requirement of a common ground, and all of the sub $100 class D/T speaker amps on the market had separate grounding and would go up in smoke if connected with a TRS adapter. And to get a balanced cable generally defeated the goal of a cheap speaker amp solution (to keep it economical). The king of affordable speaker amps for headphones ended being the Emotiva MiniX which is an AB amp and has a common ground, but is also $220. It's nice to see a potential new solution to the affordable speaker amp for headphones quandary.
Reply #41 on: July 04, 2014, 04:31:16 PM
Note to PB - I have attached a link to the full bill of materials for the Quicksand SLA battery adapter kit.
http://www.mouser.com/ProductDetail/3M/FDI18-250Q/?qs=SfU69DRKVGBj%252bw1YFkqIaw%3D%3D&gclid=CjkKEQjwodmdBRDm_ZLhorWm68UBEiQAKhO3_TzDJjUcXQ6SeXN3xDP2uRsp9BVJ2xyUV4oStf2a5Wjw_wcB
Reply #42 on: July 05, 2014, 06:07:14 AM
That's FUNNY ! !
Offline kgoss
Reply #43 on: July 05, 2014, 10:19:47 AM
Yes it is and that's why my degree is in computer science not electrical engineering!  Looks like Doc gets to keep the corner office for another week!  Heck, I'll give him the next two weeks!   8)
Ken Goss
Offline Bonzo
Reply #44 on: July 08, 2014, 03:58:47 AM
Another question: it seems headphone output isn't lowered at all (the resistors across the jack seems 0 ohm), isn't it a bit dangerous?
Ciao!
Bisogna avere orecchio!
