Newly purchased SEX kit
Natural Sound · 2648
Offline Natural Sound
on: August 16, 2014, 12:35:32 PM
I took advantage of a recent sale at Bottlehead and picked up a SEX 2.1 kit. I was planing on leaving the top plate natural. Unfortunately mine came with a big scratch by the power switch. :( Is there a good way to buff this out or am I stuck with spray painting the top plate instead?
« Last Edit: August 16, 2014, 02:14:48 PM by Natural Sound »
Reply #1 on: August 16, 2014, 12:47:26 PM
You would have to refinish the entire plate to match.  I put a small scratch on mine and tried brushing a section on the back with wirewool, sandpaper, cutting disks, various dremel bits and could'nt get anything like the same finish texture.  I ended up just leaving it alone and living with the scratch.  I would be curious to see how BH do it?
Reply #2 on: August 16, 2014, 03:16:33 PM
I finish almost all of them all myself. There is only one other person we have found who can make them look the same, and we hire him when we need to do particularly large runs of Crack panels. Doing about ten panels a day is comfortable. I have done up to 30 in a session, but it is very wearing.
I might be able to touch up a damaged plate without redoing to the whole thing, but there is no guarantee that will work and usually the whole panel would get refinished.
If I showed you how it is done I would have to kill you.
Reply #3 on: August 17, 2014, 04:49:33 AM
Right, rattle can it is. :(
Offline JamieMcC
Reply #4 on: August 17, 2014, 05:39:46 AM
If your going to rattle can it have at your scratch with some 240 wet and dry followed by some scotch brite or one of those nylon pan scrubbers only rub in one direction (not back and forth) in line with the graining.
There are some very nice looking brushed metal effect vinyl's available that might offer a option.
Offline Oberst Oswald
Reply #5 on: August 17, 2014, 06:52:08 PM
Try a electric drill or, better yet a drill press, with a wire brush attachment that has the wire bristles pointing down.  You can get this product at almost any hardware store or home depot.  There are two types... hard or soft bristles.  Depending on how deep the scratch is will be the one you chose.  Should be no more than $5.00 each.  Try to keep the wire brush as straight as possible and press down without moving.  You should have a round swirl the size of a quarter or so.  Do this for the whole plate to match with a slight overlap with each swirl.  Try this on the underside of the plate first to get the feel and see the results.
X-Fi > Stello DA100 > BeePre > SEX 2.1, Beta 22 or Bijou.    Paramounts > Extended Foreplay III > Thiel CS2
Stax SR-Lambda with SRD-7/SB
Denon D-7000
Audez'e LCD-2r2
Sennheiser HD 800
Reply #6 on: August 17, 2014, 07:06:25 PM
Metal burnishing, looks great but its a lot of work...
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.overthehills.com%2FRV-9A-Project%2FFirewall-Forward%2FEngine%2Fi-5w9GZTp%2F0%2FM%2FIMG_3816-M.jpg&hash=2538c069d3e3ab686c0025bd3434f2aadf2555e1)
