Dead Channel on BeePre
boulos · 7147
Offline boulos
on: September 01, 2014, 04:38:21 PM
Hi,
Last night I finished installing the BeeQuiet on Gerry's BeePre.  I turned the preamp on, and everything worked fine.  Today, Gerry and I turned on again to listen, and for about 15 minutes it sounded great, then all of a sudden one channel started developing noise and died out into static noise (like TV "snow" noise).  The sound from that channel is like the sound that comes out of the BeePre when it hasn't warmed up (the first few seconds of turn on).  We did all the necessary tube and cable swapping, but the bad channel didn't budge.
Voltages on both channels checked out except for OB on the C4S boards. The good channel measured ~130, while the bad one measured ~143.  I checked the potential difference between the collector and emitter of the MJE5731A transistors on both boards. On the good channel it is 15V, while on the bad channel, it is 0V.  The difference between base and emitter on both channels is 0.6-0.7V. Note that on the bad channel, the two LEDs on the B-side of the board are dim; while the 6 other LEDs (the ones on the A-side and the four on the other board) are bright. On the filament board Kreg measures 4.0V on the bad channel and about 4.9V on the good channel while +reg measures about the same on both boards.
Next, I took out the EL84 tubes from both channels and turned on the preamp.  While the good channel worked almost immediately, the bad channel slowly went from static noise, to muffled sound to low sound then to full sound equal to the good channel.  With the EL84s out, the B-side LEDs on both C4S boards are bright, while the A-side LEDs on both are dim.  Kreg and +reg on both filament boards measure equally with the EL84s out.
Thanks so much for your help.
Boulos
« Last Edit: September 02, 2014, 05:26:20 AM by boulos »
Reply #1 on: September 01, 2014, 04:40:35 PM
Did you swap 300B's between channels?
Your OB voltage being that high means the 300B isn't drawing any high voltage current.
Offline boulos
Reply #2 on: September 01, 2014, 04:50:56 PM
That makes sense. I think the dimmed LEDs corroborate that.  Two questions:
-- Why does it work with the EL84s out?
-- How can I fix that?
« Last Edit: September 02, 2014, 05:25:56 AM by boulos »
Offline boulos
Reply #3 on: September 01, 2014, 04:51:53 PM
Sorry, I didn't answer your question.  Yes, I swapped the 300Bs.
Reply #4 on: September 01, 2014, 06:21:50 PM
What were the results?  Did the high voltage at OB followed the tube?
If it did, you have a problematic tube.
If it didn't you have a loose connection somewhere in the offending channel.
Offline boulos
Reply #5 on: September 02, 2014, 05:25:39 AM
Hi Paul,
I hadn't re-tested voltages when I switched the tubes last night, but when I did, the bad channel didn't switch. I tried it again today, and OB did not change when I switched the tubes remaining at 143V in the bad channel. But... OB in the "good" channel now went from 130 to 143V!  So I exchanged both tubes for a different pair, and guess what happened, OB went to 110V on one channel and 105V on the other.  So BOTH tubes were bad!  What are the chances of that? :) Perhaps it just happened that one side was going over the edge enough yesterday to work and was throwing me completely off.
Thank you for your help!  Gladly, I changed the pair of tubes before I started melting solder joints.
Boulos
« Last Edit: September 02, 2014, 05:47:56 AM by boulos »
Reply #6 on: September 02, 2014, 05:42:55 AM
The tubes that aren't working may just have a little corrosion on the pins. Try cleaning them with a scotch brite pad or a little fine sandpaper.
Offline boulos
Reply #7 on: September 02, 2014, 05:55:38 AM
I'll try cleaning the pins. These are 10 year old EH tubes, but they weren't being used during all this time, so it is strange that both would fail.
For reference, all LEDs on the C4S boards are now bright.
The BeeQuiet was a fun build. It was relatively easy, but that is mostly thanks to the excellent instructions.  Attaching a photo :)
Reply #8 on: September 02, 2014, 06:15:17 AM
Could also be the contacts in the sockets have stretched a bit, creating intermittent contact. You can usually tighten them up a bit by working on them with a small screwdriver tip.
Reply #9 on: September 02, 2014, 06:16:54 AM
Very, very remote, that's very odd.
Oh, never mind, that's not super surprising.
If you grab a new pair of EH 300B's, you'll notice that the filament supports in the top mica got a redesign, as the old ones tended to physically fail after a certain amount of time.
Offline Chris65
Reply #10 on: September 02, 2014, 07:12:06 AM
Thanks for the photo, just what I was looking for as I start my build. What are the caps there? Some vintage Russian?
Offline boulos
Reply #11 on: September 02, 2014, 07:30:19 AM
They are Russian MBGO 10uF 300V caps.  If you install them, be careful that they're heavy. They needed some RTV Silicone to support the base of the ties. I actually thought the caps were the problem yesterday and measured them. They both measured 10.5uF and their ESR, dissipation factor, and Q were matched and very good.
Offline Chris65
Reply #12 on: September 02, 2014, 08:04:23 AM
Thanks for the info. Something to consider!
Offline mozarti
Reply #13 on: September 02, 2014, 08:56:39 AM
You may want to remove the o-ring under the tube on the offending channel.  My Beepre had occasional white noise and the problem was solved by taking the o-ring out. Apparently, the tube's pins did not have good contact with their socket on account of the o-ring.
Offline boulos
Reply #14 on: September 02, 2014, 09:24:57 AM
Thanks for the tip!  I hadn't thought about that, but since the BeePre was upside down during testing, I wasn't using the O-rings to lesson the chance of the tubes falling out. So the measurements were all taken without the O-rings.
