Changing input load
8452 · 19693
Offline 8452
on: May 05, 2010, 07:28:19 AM
I have a C4 Seduction that I am using with a Benz Micro Ace HO. The manufacturer recommends a 1000 ohm load. Which resister do I change to get there? Assume ones attached to input jacks but want to make sure.
Reply #1 on: May 05, 2010, 07:47:47 AM
You are correct, the input loading resistors attach to the input jacks and solder to the ground plane. Usually cartridges have a range of input loads they like, so you might consider buying a pair of small 50k or 100k trimmers so you can try different values.
How are things sounding with the 47k resistors?
Reply #2 on: May 05, 2010, 10:18:39 AM
I found this:
http://www.musicdirect.com/product/81700
It indicates greater than 1000 ohms.  So that gives a wide range.  Have reviews suggested a 1k ohm resistor?
Offline 8452
Reply #3 on: May 05, 2010, 02:41:02 PM
It sounds a rough right now, but its still breaking in. Highs are a little forward. I've seen blog reviews suggesting 1000-1500. I think I'll try the trimmer idea after it breaks in. Thanks
