9 pin PCB board from Auw Jimmy.
EarWorm · 3034
Offline EarWorm
on: September 30, 2014, 04:30:46 PM
When I saw these 9 pins from Auw Jimmy I had to get one for my Crack build.
I got 2.  Beautifully made, gorgeous to look at.   Take a look
« Last Edit: September 30, 2014, 04:37:23 PM by EarWorm »
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #1 on: September 30, 2014, 05:09:26 PM
What tube sockets are you using with them?
I can highly recommend these ones as they are very nice quality, and grab onto the tube nice and tight. http://www.ebay.co.uk/itm/2pcs-CMC-Bakelite-Gold-Pin-Tube-Socket-9P-Brown-Base-/130378212735?pt=Vintage_Electronics_R2&hash=item1e5b25a57f
Offline EarWorm
Reply #2 on: September 30, 2014, 06:02:03 PM
Thanks for the link. I'm open to all 9 pin suggestions since I haven't obtained an upgraded base yet.
Did you use a pin break out PCB or did you solder straight on to the base?
Reply #3 on: September 30, 2014, 06:29:49 PM
You really have to use the PCB's for the pin style sockets, i wouldn't fancy trying to solder wires directly onto them.  That seller also lists small PCB's i used on them.
Reply #4 on: September 30, 2014, 06:48:45 PM
I guess it's all perspective. I looked at the pictures from the standpoint of tech support and immediately thought about the potential for nine additional bad solder joints.
Reply #5 on: September 30, 2014, 07:22:06 PM
They are difficult to solder onto the socket as the pins soak up a lot of heat, especially on the center terminal.  They are also a pain to use when you have to solder more than one wire per terminal due to the size of the holes.  On the plus side the tube sockets are of a much better quality.
Offline EarWorm
Reply #6 on: October 01, 2014, 12:06:38 PM
I thought more folks here were using these 9 pin pcb boards from different sources like theses.  One for the Yamamoto teflon socket. This other from Parts connection.
http://www.partsconnexion.com/CONNEX-74342.html
Offline i luvmusic 2
Reply #7 on: October 01, 2014, 12:34:15 PM
 I've used those one's from Partsconnexion it's a PITA to work with the holes for the hookup are far too big.
« Last Edit: October 01, 2014, 12:37:15 PM by i luvmusic 2 »
Offline EarWorm
Reply #8 on: October 01, 2014, 12:52:26 PM
Where might one get those extra pins for the outer holes?
