uk crack builder, voltage issues
tweedgv · 4769
Offline tweedgv
on: October 30, 2014, 01:36:00 PM
Hi guys
Ive recently received my crack (yesterday), painted the chassis (yesterday), and then spent the day building it (today).
resistance all check out great, but when i came to the voltage, every terminal is measuring more than it should, way more, like double.  every terminal that should read 0 reads 0, but every other terminal is up. is there a discrepancy with uk voltages?
i've gone through the build and i cannot find a miss placed wire or such, but it is late....
thanks, any help would be great.
Gav
Reply #1 on: October 30, 2014, 01:54:19 PM
Does the power transformer say PT-3 or PT-3 240V, and/or does pin 2 say 120V or 240V? You may have received a 120V transformer in error. We can help you to figure that out and, if so, send a replacement.
Offline tweedgv
Reply #2 on: October 30, 2014, 01:57:30 PM
tranformer says 240v bottlehaed pt3
Reply #3 on: October 30, 2014, 02:04:56 PM
Ok, let's eliminate the possibility of our having sent you a mislabeled transformer. Make sure the amp is unplugged from the wall. You will want to measure the resistance from pin 1 to pin 2 on the power transformer. It should measure about 47 ohms. If it measures around 12 ohms instead, we have sent a mislabeled transformer and we will need to send you a replacement.
Offline tweedgv
Reply #4 on: October 30, 2014, 02:17:05 PM
yeah, thats fine, coming in at 48
Offline tweedgv
Reply #5 on: October 30, 2014, 02:32:21 PM
if this would help, here are my readings:
1- 176
2- 381
3-0
4- 381
5- 170
6 - 0
7 - 232
8 - 0
9 - 230
10 - 0
11 - 0
12 - 0
13 - 380
14 - 428
20 - 0
21 - 475
a1 - 173
a2 through to a5 = 0s
a6 - 174
a7 through to a8 = 0s
B1 - 174
B2 - 380
B3 - 233
B4 - 174
B5 - 381
B6 - 232
B7 - 6
B8 - 0
Reply #6 on: October 30, 2014, 02:59:22 PM
OK, the power trans is fine. It looks like the voltages are high because the tubes are not drawing any current. Do the tubes have a faint orange glow inside?
Reply #7 on: October 30, 2014, 03:28:46 PM
I have a theory, did you wire the two 150v windings in series?
Reply #8 on: October 30, 2014, 03:43:09 PM
Can you do a quick AC voltage measurement on terminals 4 and 5 on the power transformer?  That should give you about 6V AC with the tubes in.
I would really have to scratch my head as to why your voltages are so high if you didn't accidentally get a 120V transformer.
Offline tweedgv
Reply #9 on: October 30, 2014, 10:32:09 PM
ok guys....... sorry i'm late replying, had to go to bed.
yes the tube is glowing.
the reading off the power terminal:
4 = 0
5 = 6
Offline tweedgv
Reply #10 on: October 30, 2014, 10:41:40 PM
sorry mcandmar.  you've lost me.
thanks for the help though guys.
i did the last test on the TRS jack and both the tip and the ring behaved as expected....... climbed to 10 and 11 respectively before quickly reducing to 0.
i'm hoping its something stupid that i've done, and it probably is, this is my first ever project of this kind and to be honest.......
i'm babbling now......... stupid time difference ........ what time do you guys wake up anyway? haha
i'll do another wiring check.
« Last Edit: October 30, 2014, 11:26:16 PM by tweedgv »
Reply #11 on: October 31, 2014, 04:54:18 AM
Can you post an image of the wiring around the power transformer? My hunch is either the meter is giving incorrect readings or there is some issue with the transformer wiring. Also, could you set your meter to AC Volts and very carefully measure the AC voltage across pins 6 and 7 (black lead to 6, red lead to 7) of the power transformer and then measure the AC voltage across pins 9 and 10 of the power transformer? You should be seeing somewhere around 150 to 165 Volts AC. Possibly a bit higher. Set your meter to the 500VAC range or higher to be safe.
Offline tweedgv
Reply #12 on: October 31, 2014, 05:23:24 AM
OK......
both 6 & 7 and 9 & 10 are indeed giving me 167.
Offline tweedgv
Reply #13 on: October 31, 2014, 05:44:49 AM
couple more pics
Reply #14 on: October 31, 2014, 06:44:52 AM
OK, set your meter back to DC volts on a 500V or higher range. Measure again with the black test lead attached to terminal 12 and the red lead attached to terminal 13.
