Bottlehead Kits
Legacy Kit Products
Smash
PC Board resistor
PC Board resistor
Alonzo
6892
Alonzo
Sr. Member
Not all those who wander are lost
PC Board resistor
December 21, 2014, 03:37:00 PM
Getting along on my Smash build, my .27 ohm resistor reads .6 ohms (shorting my Fluke reads .1). I put it in anyway assuming it was Ok but thought I'd ask since it's almost 50% out. Will it make much of a difference in the filament voltage?
Alonzo
Paul Birkeland
Global Moderator
Hero Member
Re: PC Board resistor
Reply #1 on:
December 21, 2014, 03:42:23 PM
It can be very, very, very hard to measure low resistances like that, even factoring in the meter lead resistance.
What does your meter say when measuring the 0 Ohm resistor supplied?
mcandmar
Hero Member
Not all engineers are civil
Reply #2 on:
December 21, 2014, 03:54:57 PM
My Fluke meter (175) has a resolution of .1ohm with an accuracy of ±(0.9% + 1) so a couple of ohms is the practical limit you can measure down to.
P.S. Never heard of a 0 ohm resistor before, whats that do for you?
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
December 21, 2014, 04:17:19 PM
The 0 Ohm resistor just acts as an insulated jumper.
Alonzo
Sr. Member
Reply #4 on:
December 21, 2014, 04:20:38 PM
The 0 ohm measures .1 ohm, which is my zero since I get .1 ohm shorted.
Alonzo
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
December 21, 2014, 04:41:42 PM
Yeah, I wouldn't worry too much about it. Oils from your fingers, oxides on the resistor leads, etc. are going to influence this low of a resistance reading.
If your voltage checks end up being off, let us know and we can revisit that resistor.
Alonzo
Sr. Member
Reply #6 on:
December 21, 2014, 06:08:46 PM
Ok, Great!
Alonzo
Bottlehead Kits
Legacy Kit Products
Smash
PC Board resistor
